-   I followed the advice dated 4/22/2008, below, and restarted my Casio Forester, module #2147. The directions are also located on the inside of the back of the watch.
Bob 5/5/2009-   Guest
Nov 14, 2008
-   I have the same problem with restarting or resetting after battery replacement in two of my casio digital watches (1) casio W-740 and (2) casio SKX-1000. It seams it may be different with different models. Both these have the AC engraving on the inner metal case, but I can't work out what I need to short it across to restart it. Any ideas anyone?-   myjobsucks
Nov 04, 2008
-   can not reset watch so that backlight works
-   Guest
Jun 21, 2008
-   I have replaced the battery in my Polar S120 and now have a string of meaningless symbols along the bottom of the screen and a line across the top. None of the buttons works. How do I reset it to function?-   mikebriggs
Best Solution
posted on Apr 22, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
1) Take off white plastic cover so that the only metal cover is seen 2) Notice in upper right corner there is a "golden" pad - tiny one and in the metal cover there is an engraving AC. Use some needle like (conducting) object and connect this pin to metal cover (ground) - this will reset your watch.
I am trying to decide which Ice watch to buy but I am confused by the descriptions. What are the...
(More)
I am trying to decide which Ice watch to buy but I am confused by the descriptions. What are the maximum and minimum face sizes?
Casio Men's Sports Chronograph Alarm 10-Year Battery Databank Watch #AW80D-2AV Can you set the date...
(More)
Casio Men's Sports Chronograph Alarm 10-Year Battery Databank Watch #AW80D-2AV Can you set the date format to normal DD/MM rather than the American MM/DD?
I changed the battery on my watch and a small brass colour connector came loose and I now dont know...
(More)
I changed the battery on my watch and a small brass colour connector came loose and I now dont know where it goes. Crane Sports MD 15200
The watch has 4 buttons & I cant find a combo that re starts the hands watch is charles...
(More)
The watch has 4 buttons & I cant find a combo that re starts the hands watch is charles delon #4290 ..it has analog hands and 3 digital dials
