Question about Electrical Supplies
I have a Kohler 4cm21 K321EP generator that had ran out of oil. I refilled it, but now it will not start. Pressing the start button only gives a thump sound. What can I do to get it to start again?
  • 957 Answers
You ran it without oil it sounds like the engine is locked up. when your run with no oil the engine parts go dry and get hot and damage to engine is result. You most likely will have to rebuild the engine or get a replacement engine.
Posted on May 11, 2014
  • 1 more comment
  • allen May 13, 2014
    is their anyother possibilities, like a fuse or switch?
  • william rodriguez May 13, 2014
    i dont have any on mine but everyone is different.. whem it ran out of oil did it stop the engine and did u see any smoke?
  • allen May 14, 2014
    hi William, i'm assuming it ran out of oil and not gas, cause I heard a low sound and I went to hit the stop switch, it would'nt stop. then it just stopped on it's on. there was no smoke. I check the oil and it was out.
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
  • 905 Answers
SOURCE: Ejecting oil
More than likely it came out of the crank case vent. Your intake valve could have been stuck open (for some reason) which pressurized the crank case.
Posted on Jun 12, 2010
SOURCE: I have a new Kohler 12kw res generator on propane - backfiring
did you put the propane orifis in and unplug the spark wire
Posted on Sep 20, 2010
GeneratorDan
  • 44 Answers
SOURCE: My 18RESL Kohler Propane Generator ran for 8.5
You have to reset it because it locked out on on under frequency. Just pullout the fuse on the control panel and then reinstall it a couple of seconds later. Now it will reset the fault codes. Hope that helps.
Posted on Dec 02, 2010
  • 15 Answers
SOURCE: my kohler 5000 generator will not run unless I keep the starter button depressed
First thing to do is get a "Wiring Diagram" for your Unit.
Once you get the diagram, just Follow the DC Ignition Power path from
the Battery, on thru to the Ignition Coil. Somewhere you aren't getting
12Vdc to the Ignition Coil, UNLESS the Start Switch is in the Start Position. It shouldn't take longer than about a hour, with a VoltMeter to find where the circuit isn't being "Made", and fixing or replacing that part. More solutions to different engine and generator problems at http://solosmallengine.blogspot.com/ and http://solo.ecrater.com
Posted on Jun 08, 2012
My 20kW Kohler home generator (nat gas) cranks but won't start. Definitely getting fuel. Everything checked in October with new spark plug. Maybe a setting?
Did you check the oil level? Some generators have a oil sensor that will now allow it to start if the oil level is too low.
Mar 14, 2017 | Kohler Electrical Supplies
We have a Maxa ER 5000 Tecumseh Generator, changed the oil and spark plug, no fire. How do you check the low oil switch?
Nancy, If you think this is the problem, simply unplug it. See links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Disconnect Your Low Oil Sensor
Re Testing Low Oil Sensor on Honda GX Engine
How to Test the Low Oil Pressure Switch on Generator
Generator runs then shuts off
Feb 26, 2016 | Electrical Supplies
Trying to find what oil filter can be used in 14KW Kohler
what is the filter part number on the Generator now? Give that to an Auto parts place and they will cross it to what they sell
May 05, 2015 | Kohler Electrical Supplies
Have generator showing emergency stop code and will not start.
there are too emergency stop sensors on generators
one is over load
the other is low oil level in the sump (Low oil pressure)
That sensor is known to trigger and activate the emergency stop so check it out after you check the oil level in the sump
Feb 26, 2015 | Kohler 20resa 20kw Home Emergency Backup...
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Kohler generator wont stay on
Check the oil pressure switch, and oil level first. Then check rotor brushes and rotor slip rings may need polishing. If the problem is still there check stator and rotor windings
Aug 25, 2012 | Kohler Electrical Supplies
Wont run unless you hold in start button
You didn't list model number, but I'd check the oil pressure switch and any other safetys in the circuit. Kohler makes a wide range of genaerators from small ot very large.
Jul 24, 2010 | Kohler Electrical Supplies
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
Aug 11, 2009 | Electrical Supplies
Electrical Supplies Logo
121 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
