Question about Yamaha RX-V373 5.1 Channel AV Receiver
Won't power on to play
Unit does not power on if just using power button. If I select Straight, Tone Control, and Power, then it powers up to a menu that first says "analog bypass." Trying the factory reset does nothing. What else can I try?
  • 336 Answers
SOURCE: Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
Posted on Jan 12, 2009
smarthome2
  • 1114 Answers
SOURCE: How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Posted on Jul 01, 2009
Grubhead
  • 5190 Answers
SOURCE: hope it hasn't been fried but unit is not powering
Try checking the internal fuse(s). Then check the on/off switch. The other thing to consider is the transformer.
Posted on Mar 05, 2010
dunnbiker
  • 8546 Answers
SOURCE: Yamaha Amp RX-V1700B Receiver - no power to head unit
Go to the shop.
Posted on May 28, 2010
Testimonial: "Thanks - I came to the same conclusion myself - hopefully something simple and not too expensive."
dunnbiker
  • 8546 Answers
SOURCE: i turn on the unit,after
If it won't turn on with NO speaker wires attached, it will probably need a technician to look at it.
Posted on Jan 12, 2011
How do I unlock my Coby Series MID7034 Forgot the pass code?
This procedure will delete all items (files) and entries on the MID7015-please back up files on your computer if possible first. This is a Master Reset Procedure.
  1. Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
  2. Click "Power Off" and select "OK"
  3. Once the unit has been turned off. Press and hold the "back" button(silver tone button) and "power" button simultaneously for eight seconds.
  4. When the Android Icon and warning triangle appear , press the "back" button )silver tone button) once.
  5. The Android recovery screen will appear. The "Home/Menu" button will allow you to scroll up and down.
  6. Press the Home/Menu button to scroll to "Wipe Data/Factory Reset" Then press the "back" button
  7. On the next screen Scroll to "yes-delete all user data" Press the "back" button.
  8. On the next screen Choose "reboot system now" and Press the "back" button.
  9. You will now be able to access the tablet.
Sep 17, 2016 | Coby MID7036-4 7" Capacitive Multi-touch...
How to hard reset a craig 7 inch netbook
1. Power off the unit
2. Press "Power On/Off" and "VOL+" button together until "Android recover Robot" appears then release.
3. Press and hold the power button then right after press the volume + button then release. repeat until the blue menu appears.
4. In recover menu, "Volume +" & "Volume --" button control "Up" & "Down", Power On/Off button as "Confirm" button
5. Select the option "wipe data/factory reset"
6. Press "Power On/Off" button to confirm, scroll down using the volume - button to option stating "Yes -- delete all user data" and press "Power On/Off" button again.
7. Select the option "wipe cache partition" and press "Power On/Off" button to confirm
8. Select option at the top of menu "reboot system now", press "Power On/Off" button to confirm selection.
Aug 04, 2015 | Computers & Internet
Why is my laptop comming up with aptio setup utillity
Try this
1/ Select the Boot menu in the Aptio setup utility, select 'Launch CSM' and change to enable
2/ Select the Security menu n the Aptio setup utility, select 'secureicon1.png Boot Control' and change to disable
3/ Select Saveicon1.png & Exit and press 'yes'
4/ Hold down the powericon1.png button until the unit switches power off completely
5/ Switch back on and continually press the F9 button for about ten seconds; this should now allow the unit to boot up into the Windows Recovery menu
6/ Select 'Advanced Start Up' and wait until the recovery menu appears
7/ Select ' Advanced Options'
8/ Select 'System Restore' and select a date prior to when the problem occured
System Restore worked perfectly for me; good luck
Aug 03, 2014 | ASUS Computers & Internet
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
My straight talk LGL55C powers up and goes to the blue tracphone blue screen and won't power off with power button or anything
Take the Battery out.
Place it back in.
Press and hold the Vol down : Home : Power buttons simultaneously for 10 sec.
Using the volume buttons navigate to the reset to factory settings option.
press select (left of home on L55C).
Confirm to reset.
Select to reboot.
You should be good.
Oct 30, 2012 | Cell Phones
Yamaha RX V671 will not turn on anymore after a power outage
The protection mode has activated.
Reset the protection mode as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Apr 10, 2012 | Yamaha Audio Players & Recorders
Forgot pattern on coby android
Nov 08, 2011 | Coby MID TABLET PAD WITH TOUCHSCREEN
I have a convection bread maker. I made one loaf of bread tonight and i unplugged the machine. 30 minutes later, I tried to make a second loaf ant the menu select wouldn't work but the start and mix in...
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Jun 13, 2011 | Cuisinart Kitchen Appliances - Others
Wrong region.on screenhelp please
try to make it region free by using the steps below
1 Press power on
2 Press set-up
3 Select preferences menu
4 Press play
5 Input 251131
6 Press "Left" then "Down" button
Should show region code
7 Select region
8 Press set-up to confirm and exit.
or
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
or
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
3 Press set-up
5 Press play
6 Input 251131
Nov 27, 2008 | Mintek MDP-1770 Portable DVD Player
Cyberhome dvr 1600 dvd recorder
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
Feb 09, 2008 | Cyberhome DVR 1600 DVD Recorder
Yamaha RX-V373 5.1 Channel AV Receiver Logo
110 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
