Question about RCA D52W19 52" Rear Projection Television
I have a RCA HDTV that was working fine until this morning the TV went off and when we turned it back on the green light came on for about 40 seconds with sound and then the light went off and the TV was off again. We tried this off and on but after awhile it almost smelt like some rubber burning, so we unplugged it in case there was a short. Does this sound like a short and if so what can one have done? Mary in Omaha
    Brigadier General:
  • 8,619 Answers
Hi Mary
The first this one should do is unplug the unit completely from the mains, then check for any burned wires. Also let me know if its still under warranty as opening up the unit will void the warranty. If the unit is not under warranty then open up the TV check for cold solder joints, burned capacitor/transistors.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 23, 2009
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Phillips 32" HDTV power light blinks green but wont turn on
the problem in the main power supply it depends of the kind of faillure but normaly to repair it not very expensive
good luck
Aug 23, 2009 | RCA F32650 32" TV
Tv turns on then right back off no pic or sound
It is in shutdown mode. You have an "overvoltage" (regulation) problem or their is a short in one of the many components causing it to be in "over current" mode. Could be as simple as a bad solder connection. This will take someone with some knowledge of the circuits and test equipment to diagnose.
Jun 25, 2009 | RCA HD56W66 56" HDTV
RCA 52" second time in the shop in less than one year, won't stay on, green light flashes 3 times then goes out
try changing the cap 150 on the same board as flyback transformer this should help with the tv not staying on.
Jan 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" RCA Rear Projection.
This will require tech repair.. the processor is dectecting problem. does the green light flash?
Nov 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
RCA D52W19 52" Rear Projection Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
