I turn on the power but the screen that say "onetouch Evolve" comes on and that it . It will not load up
SOURCE: Baby Lock Evolve wire Looper threading tool
You have to get the replacement wires from a Babylock dealer, I did too then after sticker shock at the price of that wire I learned to make a thread cradle and use that to thread difficult threads no. Take about 24 inches of regular sewing thread and fold it in half, put the open ends (together, same legnth) into the jet air port and hold onto the loop end, press the jet air threader and it will thread the machine, insert the thread you want to use into the loop you have in your hand and pull it thru the machine using the ends of the thread you put thru the machine, sounds harder than it is and works all the time. No more spending $8 on replacement wires. You can use this method for all the jet air sergers.
SOURCE: Baby Lock Serger Instruction Manual
Baby Lock offers free downloadable instruction manuals for their products. Go to http://www.babylock.com. Find your model's product page; for example, mine was the Baby Lock Evolve Model BLE8W. Once on the product page for your particular model, you will find a link towards the bottom that says "Manuals & Guides." Click on this link and there will be links to download the manual and anything else, like a Quick Reference guide.
SOURCE: griffin evolve remote not functioning
how did you take off the back to put in new batteries... try syncing your speakers by holding the 2 volume buttons on the base at the same time for about 2 secs.... the light will start to blink and you just click any button on your remote. If that doesnt work then its firmware
SOURCE: griffin evolve speakers
The back plate is definitely snap off. As teodo mentioned, do not pull the entire rubber backing off. On the bottom and sides of the back plater there are two snaps, each directly on either side of the wider ridge along each edge. The top is a different problem. The snaps are on the speaker side and clip onto the bottom of the upper edge of the back panel. To remove the back plate: Start on the bottom of the speaker at the back edge. Pull away the rubber edge carefully to expose the joint between the back panel and the speaker box. Along the center of the of this joint on the panel is a wider ridge. Place a thin flat edged tool on one side of the ridge, pry, then push forcibly until the inner edge of the back plate is apart. Do this to each of the edges on the bottom and sides of the speaker. Don't peel away any rubber on the top side of the speaker. Press your flat edged tool into the joint and lift gently the back plate side of the joint before pushing it out. This will disengage the clips on that edge. If you're looking to replace the batteries, they are 3.5V 5200maH. Take Care
