Question about Compaq Presario SR1030NX (DW256A#ABA) PC Desktop
How do i set a seagate barracuda 7200 hd to slave
  • 641 Answers
You don't need to setup as a Slave drive like IDE drives. You simply install the new SATA drive on an open port and follow the steps in this thread to format the hard drive. This will allow the hard drive to be used as a storage drive or whatever you plan to use it for.
Guide: If you installed a new disk but the system can't see it
Posted on May 11, 2014
I have a ST3750330AS SATA HD and wish to know the jumper settings. Thanks
CS (cable select) for primary drive (Default setting anyway)
SL (Slave for secondary)
Dec 23, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How do to install slave drive Seagate Barracuda 7200.9. Does it has to be to the motherboard or to a card in my computer? How do I set the pins in what order?
if y0our going to slave one hardrive you need to set that hardrive jumper into slave format....check your hardisk if where pin should it e placed...usually there is a direction where to set the jumper for slaving the hardrive.
Oct 28, 2009 | Seagate Barracuda 7200.9 ST3400633A 400 GB...
How do I set my 7200 Seagate drive as slave
Look at the diagram on the drive, you will need a jumper
MA = Master
SL = Slave
CS = Cable Select
If it's EIDE use the center connector on the cable
Oct 25, 2009 | Seagate Barracuda 7200.10 750 GB SATA Hard...
Hard drive failure segate barracuda 7200.9 it is two disks raid striped is there any way to remove data from disk or any way to connect them to another machine as a slave
how about scanning and trying to repair the sectors with hirens boot cd. There is a utility on it called hd regenerator or something like that http://www.hiren.info/pages/bootcd. I think you have to download this cd from piratebay first. There is no download from his website.
Sep 14, 2009 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Aug 22, 2009 | Seagate Barracuda 7200.7 Hard Drive
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How to tell which jumper is master and which is slave
Master is 7-8 (the 2 furthest from the power connector)
Slave is no jumpers selected
Here is a manual for your model for reference:
http://www.seagate.com/support/disc/iguides/ata/cuda7200ig.pdf
Mar 28, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 200 GB 7200 RPM
can you take a snapshot from the smart page?
Feb 22, 2008 | Seagate Barracuda 7200.7 200 GB Hard Drive
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
See all Compaq Presario SR1030NX (DW256A#ABA) PC Desktop Questions
Compaq Presario SR1030NX (DW256A#ABA) PC Desktop Logo
81 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
