Eror 021 electrolux w455h
  • 641 Answers
Try to check this video
Posted on May 11, 2014
What is the solution of error35 in w455h washing machine
Hi! If you mean error F35, this error code indicates an analog pressure sensor error. This sensor is the component that detects water level in the washer tub.
F35 error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor.
Apr 27, 2017 | Washing Machines
Electrolux w455h washing machine is comming error 45 moter not floow..what is the reason comming like this????thanks...
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Apr 05, 2016 | Electrolux Washing Machines
Which is more reliable..a stihl 017 or a stihl 021 ? looking to bid both in good runnung shape...thanks
Hi, you cant go wrong their both stihls. The 021 is a more powerful saw and the 017 is lighter, so it all depends on your intended use. Regards Phil.
Jun 26, 2012 | Garden
Sir, i am working washing unit company,i am having one problem in w455h 6kg machine,in my unit all washing machines are connected in plc and pneumatic valves,then the problem is water in automatically not...
This might not help you- if not, I'm sorry.
Does each machine have its own water outlet filter? If so I would suggest as a first step that you clean the drain motor lint tray/filter.
Here are my complete, general pre-typed guidance notes for checking the filter ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Hope the filter is the problem and good luck!
John C
Mar 16, 2011 | Electrolux Washing Machines
Error code 021
Press
Function
7
monitor slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for the fax to initialize and come back to READY
Sep 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Stihl 021 running poorly
Couple of things I would check first. Place a funnel in a can with a paper napkin covering bottom of funnel. Pour the gas from the saw into the funnel. If there is a lot of trash in there, remove the fuel line from tank. Clean the filter with carb. cleaner. Then clean the tank with carb. cleaner. If you still have problem. Replace the Air inlet tube, (clear tube with screw type device close to carb).
Apr 15, 2009 | RTO Spur Sprocket For Stihl 017, 021...
I have a stihl 021 chainsaw that will crank and idle fine however it will not throttle up to full speed ,it will accelerate to about half, then it just like chokes out.
For the 021...on the muffler, there is a spark arresting screen, this is to prevent sparks from coming out of the muffler. It is common for this screen to become clogged with carbon from the engine. You will need to clean/replace this screen in order for it to run correctly.
Feb 28, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
