Question about Pool & Spa
Starite sr400lp runs fine ,no errors however water to pool is not hot or even barely warm
Hello all I have sta-rite sr400lp heater, it runs fine with one exception the water going into pool is not hot, it is barely warm, so i am wasting fuel trying to heat the pool. I have no error lights, codes or anything suggesting ANY problems. anyone have any thoughts? help is most appreciated. Joe
  • Joe T
    Joe T May 14, 2014
    yes exhaust is hot, but outlet to pool does not get warm it stays the same temp as the inlet, even after about 20 minute of heater running. there are no visible leaks anywhere and it runs as it did on day one, with the exception of said issue. Im stumped its driving me nuts.
    Scholar:
    New Friend:
  • 66 Answers
With heater running put your hand by the exhaust and see if the air being expelled is hot. It will be if heater is producing heat. Depending on the size of the pool this heater can take some time to heat the water.
Posted on May 14, 2014
  • Joe T
    Joe T May 14, 2014
    yes exhaust is hot, water at outlet is not warm even after 20-30 min it is same temp as water going in, there are no visible leaks or anything else that would appear suspect, it looks/runs as it did on day one with the exception of said issue, this is driving me nuts.
5 Suggested Answers
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
jharwell668
  • 640 Answers
SOURCE: sta rite pool heater error r=5?
The users manual for these pool heaters has a chart that walks you through, step by step, a troubleshooting guide. That is the best way to find a solution to your problem because it asks pretty specific questions that you have to be looking at your heater to answer. Here is a link to the pdf file.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 16, 2010
jharwell668
  • 640 Answers
SOURCE: Sta-Rite Max-e-Therm pool heater shows error code
These pool heaters have a detailed users manual that has a great troubleshooting guide. I would try there first. They ask alot of questions that you have to be looking at the heater to answer. Here is a link to an online version.
  • 5 Answers
SOURCE: I have a e05 error
check the sensor that is on the exaust
Posted on Sep 09, 2010
Error 180 / r 9
not an error code! part of the start up sequence
Aug 18, 2014 | Sta Rite StaRite SR400HD Max Therm Pool...
Starite sr400lp runs fine no errors, however water to pool is not hot, or barely warm
soulds like maual bypass is stuck letting too much water flow through heater and doesnt have enough time to heat it the spring is probably stuck
May 11, 2014 | Pool & Spa
I have a Starite heater, natural gas. I replaced the thermistor for the second time in two years. The problem again has returned with the R6 code. The heater just doesn't seem to get hot enough. Shoul
you might want to add a bypass to the heater and not let the full return water through it this is called temp rise to slow the water down so it gets hotter
Apr 30, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Water Isnt Getting Hot
Could be that the plumbing got clogged while the system was idle
May 13, 2013 | Sta Rite Pool & Spa
How close can a sta rite gas heater set next to a a/c condencing unit
If you are a technician and have to ask this, then you shouldnt have your gas license. Why would a pool company send out a tech to do gas work who doesnt know even the little things? Try reading the manual!
Feb 17, 2013 | Sta Rite Pool & Spa
Capacitor needed
I don't know what capacitor you need but if it is part of the Sta Rite heater then I would call Sta Rite technical support at 888-782-7483 and they could likely help you come to a resolution.
Please let me know how this works out. Thank you.
Sep 02, 2011 | Sta Rite SR400LP Max E Therm Pool Spa...
What does R8 code mean on sta rite pool heater
These pool heaters have a very detailed and specific troubleshooting manual that will probably be the most helpful thing for you. They ask very specific questions about what appears on your heater and you will need to be looking at it to troubleshoot. Try walking through the troubleshooting guide below.
Jun 24, 2010 | Sta Rite SR400LP Max E Therm Pool Spa...
What does R* mean
Where is this "R" if it is the one in the model SR400LP That is Rite, SR Sta-Rite, 400 is btu's in thousands, LP is liquid petrouliem or propane.
STARITE MAXETHERM 400 - THERMAL REGULATORS KEEP GOING BAD
water never actually comes in contact with above mentioned part,so i dont believe your htr knows or cares whatv system you are using.since its number 4 i would suspect a main board problem.voltage readings would be helpful
Jun 21, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Pool & Spa Logo
76 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
