I have a phillips go gear muse http://www.p4c.philips.com/cgi-bin/d...n=SA2MUS08S/17 this exact one, the power button has been broken the power button is similar to the ipod touches, the button just got stiff and wouldn't move so i took it out and started using a pin to turn it back on, is there a feature to just keep this always on? i even looked through settings and i have the power saving mode always on, and the sleep timer set to off, but it still turns off after a while and it is very hard to turn back on. The player just turns off during charging but when it is off charge it remains on until battery is drained any help please?
  • 52 Answers
SOURCE: Philips HDD082/17
when this unit gets stuck on screen usually caused by not safely removing hardware from computer. in that mode you press power and vol + button at same time for a couple seconds and will reset. sofware available through philips website: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=HDD060/17&slg=AEN&searchtxt=HDD0
Posted on Aug 20, 2008
  • 3 Answers
SOURCE: sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Posted on Sep 04, 2008
SOURCE: driver and software solution
ayudenme a conectar mi wb cam
Posted on Sep 22, 2008
  • 3 Answers
SOURCE: reseting now wont charge or turn on
Y'all should go to http://www.mymusix.com and download the "player update" (among other tools) to solve this problem. I just bought a returned one today from Radio Shack and had to spend over an hour to get it calibrated properly. It was pretty crazy...I had to press down on "play" and the "reset" buttons simultaneously and then plug in the USB cable, let go of "reset" and then let go of "play" once the "player update" software recognized the darn thing. It's now working perfectly and actually a great deal for $20.
Hopefully you can use the FAQ section on mymusix.com and figure it out exactly, otherwise I'd be happy to give you the step-by-step instructions I followed.
Posted on Oct 31, 2008
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
Nee a manual for philips gogear vibe mp3 player. and dont know how to put videos on the go gear vibe mp3 player
There are several different submodels of the SA2RGA. You'll find the manuals for them at the following sites:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA04R/37
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA04S/37
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA08K/37
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA04KS/37
Jul 13, 2011 | Philips GoGear SA2RGA MP3 Player
Need user manual
HDD1830/17:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=HDD1830/17&slg=en&scy=US
HDD1830/17B:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=HDD1830/17B&slg=en&scy=US
Jan 26, 2011 | Philips GoGear HDD1830 MP3 Player
Just received phillips mp3 player. how do i get a manual?
http://www.p4c.philips.com/files/s/sa1vbe08k_37/sa1vbe08k_37_dfu_aen.pdf
Dec 11, 2010 | Philips GoGear ViBE SA1VBE08K MP3 Player
There Is Not a Manual With Go Gear RAga 2Gb Device which i have just purchased
Depending on the model of the RAGA 2GB device:
SA1928/37B:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1928/37B&slg=en&scy=US
SA1929/37:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1929/37&slg=en&scy=US
SA1929/37B:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1929/37B&slg=en&scy=US
Dec 07, 2010 | Philips GoGear HDD060 MP3 Player
Can I get an instruction manual for the Philips DVP3345V/17DVD PLAYER / VCR combo? Problem is continuous, we still can't find it. We tried lookink in all the drawers and boxes.
DVP3345V/17
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DVP3345V/17&slg=en&scy=US
DVP3345V/17B
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DVP3345V/17B&slg=en&scy=US
Dec 05, 2010 | Philips DVP3345V/17 DVD Player/VCR
Device not recognized
Product selector site for the HDD120:
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=ENG&searchtxt=HDD120
For support on the matching model:
1. Enter your country in the top right.
2. Enter the exact Model Number on the left.
When more devices show up, select your model from the list.
Use next information and guide to get the player connected:
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?scy=US&subrequest=1&mid=Link_FAQs&new_tmpl=1&session=20091204185048_94.214.10.98&desc=Philips+Jukebox+HDD120+20GB*&view=aa12_view_full.html&list=aa12_list_partial.html&slg=ENG&refnr=0021019&refdisplay=PI_C48_PHOENIX_ARIZONA_023&dct=QAC&ctn=HDD120/17
Download link for the GoGear device detection:
http://www.p4c.philips.com/cgi-bin/dcbint/get?url=/sca/sca/060214/060214143352_10792.zip&ofn="Detect Philips GoGear Device_v3.zip"
Need more help ? Just post a comment.
Dec 04, 2009 | Philips HDD120 MP3 Player
Is a phillips GoGearvibe compatable with itunes
There are 38 variant players for the GoGear Vibe, see next page:
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=ENG&searchtxt=GoGear+ViBe
Look up the exact model in the list, revealing in what country the model is being sold. Remember or write down the exact model number, you want to check the players' compatibility with iTunes for.
Select your country in the page top and enter the model number on the left side, e.g. United States + SA1VBE04B/17. Next model will show up:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1VBE04B/17&slg=ENG&scy=US
Put in the bar "Search for information about this product" the word iTunes, go for a search and next Frequently Asked Question is listed:
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?slg=AEN&scy=&ctn=SA1VBE04B/17&refnr=0075168&dct=QAC&session=20091120183537_94.214.10.98&searchtext=itunes
The link tells how to transfer iTunes music for this model player, the SA1VBE04B/17 .
Nov 20, 2009 | Philips GOGEAR SA6045 MP3 Player
48 people viewed this question
 Grubhead
Grubhead
