Question about Music
I have the same mixer (behinger europower, 12 channel). The other day it was being used for a regular speech when suddenly all lights on the mixer started flickering and the sound got cut. After about 30 seconds, it started up on its own and the sound came back. Any idea why this would happen? It has happened at least 4 times before.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 142 Answers
You do not specify what model you have.
It could be related to the power supply shutting down (e.g. from overheating) then restarting after cooling down.
If the mixer has a fan, you could check if it is uncovered, clean and running.
Posted on May 11, 2014
mighty thor
  • 51 Answers
SOURCE: Channel mixer problem- No channel B output.
I assume you looked at the pan assignments.
what kind of mixer is this?
Posted on Dec 02, 2008
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
  • 5603 Answers
SOURCE: left channel out on behinger ub2222fx-pro could us
Behringer only give the manuals to their authorized service agencies I am told.
Mixers are very symetrical and have lots of diagnostic capability from the outputs.
If you headphones work, chances are the moxer biss es are OK which probably focuses the problem on the output drivers.
Use headphones to see what jacks work... Remember that a stereo headphone will only have sound on one side for the mono jacks you test.
If your mains have a dedicated slider, one half of the slider could be bad. Usually you can tell those by a rougness as you slide them.
Posted on Feb 08, 2010
  • 5603 Answers
SOURCE: my 94 blues deluxe switches channels by itself
IF YOU ARE USING the footswitch, then likely problem is with cable and or the pug and jack.
IF YOU ARE NOT using the footswitch the contact switch on the jack for the footswitch is PROBABLY intermitent contact. These jacks are POOR quality in the music equipment. If this is the case in yours, open the unit and tighten the spring contact.
Posted on May 08, 2010
  • 2468 Answers
SOURCE: I own a Peavey XR696F
check any and all filter,cross-over,and de-coupling capacitors in every circuit especially on the left channel side,but check all capacitors anyway on both channels,as one channel can affect both left and right channels, also a capacitor can heal itself over time and do the same thing again later,"Cold-Solder" joints can do this also, on a printed-circuit board, HINT:heat and cold can cause problems so,try heating, joints,caps,etc. or buy a can of freeze mist(to cool components) at an electronic parts store and gently heat or cool each suspect component waiting for the outcome,or wait till the condition starts and then try the cooling,because the component has already been thermally warmed up by the circuitry power
Posted on Jan 31, 2011
Where are the main speaker cables connected to in a behinger europower pmp 2000 mixer amp
The Behringer PMP2000 uses Speakon jacks on the speaker cables. The outputs are located on the back panel. Which ones you use is determined by how you configure the mixer. The Main inputs are located on the right side of the face of the mixer.
Dec 31, 2014 | AMP Music
How do i connect focusrite to europowered pmp4000
You don't say what item of Focusrite equipment you are trying to connect or for what purpose. Most focusrite stuff has jacks with analog outputs for each channel that can be used into the line ins on the mixer and jack/xlr combos that can be used to take a signal to the focusrite box. Then you get the firewire side for the PC and digital outputs as well which will not be of use with your mixer.
Feb 12, 2014 | Behringer Europower Pmp5000 Powered Mixer...
The special effects does not work on my europower 3000 mixer
Unfortunatly getting parts to fix older Behringer gear is next to impossible. i would suggest jut replacing it. If the ret of the mixer is working i would imagine it would sell for $100-150.
May 30, 2017 | Music
Behringer Europower PMP2000 Fuse keeps blowing when the amp is switched on.
For goodness sakes do NOT replace the fuse... doing so causes more damage inside. Likely one of the power amps has shorted and may have damaged the power supply as well. Also please read my tip on Fixya regarding a HAZARD with channel A if you use 1/4 inch plugs with the speaker cables. Essentially the sleeve of the channel A plug is the hot, and not the tip. Ground the sleeve of the plug and you can blow the channel A amp. YOU WILL NEED TO TAKE THE UNIT IN FOR REPAIR... THIS IS NOT A DIY REPAIR!!!!
Aug 23, 2011 | Behringer Rx 1202fx 12 Channel Line and...
One channel working and one not
Yep... failed channel... most likely "A" channel? There is weak insulation between two layers of conductors on the power amp circuit board that breaks down and blows out the switching transistors for that side... it is usually the rear-most amp. Repair of the board takes GREAT skill in restoring it as the burned area must be ground away and re-insulated and jumpers put in to replace the circuit that has to be removed. The blown components then have to be replaced. One can buy a new HCA2400 amp module for about $155, but delivery takes forever. Also please read my tip on Fixya regarding PMP Behinger powered mixers of a hazard when using Speakon to 1/4 inch speaker cables/adapters.
Aug 15, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
None of the channels work. Most of the LED lights work. Im going thru the beringer mixer for power but using another mixer.
If you plug into the PA input or inserts of this unit, that DISCONNECTS all the mixing channels within this unit and none in this unit will work. That is how it is supposed to work.
If you wish to use another mixer as well as the channels in this, I suggest you run the other mixer into one of the stereo channel inputs OR the CD inputs, although the CD are NOT balanced inouts and subject to higher noise level.
Feb 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My Behringer Europower Pmp5000 Powered Mixer blew one of my speakers and then it burnt out one of the outputs.
Probably the channel A went. If you are fortunate, the power supply is still OK. There are protection circuits for the speakers, however you MUST use speakers that are rated at over 400 Watts. If you use smaller ones, they can get blown. There is a weakness primarily on insulation for channel A and an arc between layers of a circuit board can wipe out several transistors and a zener diode and sometimes a metering resistor. Once this happens, have unit serviced before using it again as further damage can result.
ALSO PLEASE read my tip I posted on FIXYA regarding a grounding hazard when using Speakon to 1/4 inch speaker cables... essentially the barrel of the 1/4 inch jack of the A channel is the hot lead, NOT the tip for that channel.
Nov 26, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Left channel out on behinger ub2222fx-pro could use a service manual. Thanks in advance
Feb 07, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
