Question about Samsung RB215LASH
Refrigerator tempature to warm Samsung french door modle RB215LASHB4/xaa
Replaved sensor 2 weeks the refrigerator was warm again help?
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Posted on Jun 21, 2009
carlsbiz
  • 1124 Answers
SOURCE: My icemaker in my large French door Samsung
There is no way to speed it up..
If the bucket is empty - 2 to 3 days to fill is normal..
It takes somewhere around 37 minuets for new cubes to freeze,, then dump.. Cant make the ice freeze faster..
If it has a inline filter on the water line - replace it.. If it is clogged it could slow the water that is going in..
If you-all use allot of ice and empty it before it catches up - I would suggest getting a bag of ice from the store and put some in the bucket to keep the ice level up..
Have a nice day...
Posted on Sep 08, 2009
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
toolkits
  • 1099 Answers
SOURCE: 27 cu. ft. samsung refrigerator, side by side with
Troubleshooting an Ice Maker that won't Make Ice
Troubleshooting an ice maker is very important if you have problems with it. If you are having problems making ice with your ice maker then this is a very serious issue which will need to correct. If you are suffering from problems with your ice maker then there are a few simple things that you can do to diagnose and correct the problem yourself.
Checking the LinesThe first thing that you should do is check the water supply lines to ensure that they are not blocked. Sometimes ice can block the lines which may mean that they need to be cleaned out.
If the fill tube is frozen then this might need to be defrosted so that you can use it again. If the tube is too badly damaged then it might need to be replaced.
Broken LinesIf the lines break or become damaged then they can prevent water from getting to the ice maker. In this case the lines will need to be replaced so that you can restore the functioning of your ice maker.
Not Connected to WaterIt's also worthwhile checking the connections between your freezer and the water lines. If your freezer is not connected to the water lines, or if the tap is turned off then this will cause the same problems. There will not be any water available to make into ice. This is a very easy problem to correct and shouldn't take long to identify.
If you are not able to get any water from your freezer either then this suggests it could be a problem with the water supply. You will probably hear a buzzing noise when you're trying to make ice, this means that the freezer is trying to pump water which isn't available.
ValvesThe valve which is connected to the tap could also be damaged or broken. Check the valve opens and closes correctly and consider replacing it if it is damaged.
Too WarmIf the freezer is set to a too warm temperature then this will also create problems with producing ice. You will also notice that this isn't keeping your food as long as it should do. To correct this problem you will need to change the thermostat on your freezer so that it is lower.
Checking the Bail WireThere is a bail wire inside the ice maker which will lift when the ice maker is full of ice. This is designed to prevent too much ice being produced. If the bail wire is stuck in the up position then this will be preventing ice production.
Check the position of the bail wire by locating it inside your freezer. The instruction manual should help you to locate this wire.
SolenoidUnplug the freezer and pull it out from the wall. The water will travel to a solenoid located at the back of your freezer before being sent to the ice maker. If the solenoid is not working or is not getting power then this could be a reason for concern. If you're not skilled at home electronics then you might want to hire a specialist to help compete this task for you
Good luck
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: Samsung refrigerator Not cooling below 45 degrees
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dffg
Posted on Sep 29, 2010
How to repair Samsung rf265abbp/xaa door flap spring
I would need to see this to even have an idea as to whether it can be repaired.
Oct 29, 2016 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ...
www.searsoutlet.com > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
Jan 12, 2016 | Samsung Rs261mdrs 26 Cu. Ft. Sxs...
Freezer freezes food, but why is ice cream melting?
Hi
It would be helpful for the model as some samsung models are single cooling and some twin cooling,please supply the model and i will be able to help.
Bryan
Dec 29, 2015 | Samsung French Door Refrigerator Right...
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
Jul 11, 2017 | Samsung 19.7 Cu. Ft. French Door...
Samsung Refrigerator MODEL RF263AEBP/XAA. Freezer is Cold But Refrigerator is Warm
remove back cover in the freezer and check the evaporator fan motor. Also see ice patern. Possible defrost problem
Aug 24, 2014 | Samsung RF265AA Bottom Freezer French Door...
No water when water filter is replaced for RFG298HDRS/XAA
You are not screwing the new filter in right/ it is not seating. I experienced the same problem; you need to "break the seal" on the new filter.
Apr 03, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
KENMORE MODEL 253.54362409 KEEPS DEFROSTING
Sounds like your defrost sensor is acting up because after you unplug it then it works for a week or so.
Dec 25, 2017 | Kenmore Refrigerators
Samsung RB215LASH Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
