Question about Garden
Lights will not turn off
Light relays stay powered up
    Problem Solver:
  • 16 Answers
Check power to the relay with the correct voltage tester for the system. If powered the circuit will remain closed keeping the lights on. If not powered, the relay is most likely stuck and you may be able to tap on it lightly and get it to release. It will need replaced if this is the case however because it will most likely happen again.
Posted on May 11, 2014
I turn the car off and the lights stay on and the a/c or heater still stay on... When I say light everything on the dashboard
I suspect there is a relay that is bad. Look for a power relay and unplug it,and see if light go out. the relays should be in a fuse box. Some vehicle have 2 fuse boxes(Under hood and under dash) check both and look for a power relays
Feb 26, 2016 | Cars & Trucks
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Could I make a kill switch for my 99 r1 that would turn off and turn on all the lights and power? Currently my bikes lights and everything will stay on even with the key off and out the ignition. The bike...
Easily If you could wire it up to a relay the relay can turn off several things and turn on several things if you solder to the correct terminals. Is this for anti theft or is it in case you fall off the bike? :)
Nov 29, 2013 | Motorcycles
I have a 1999 dodge caravan. Passenger sign turn signal flashes for a short period & goes solid. Reverse light & brake light work just fine. Multifunction switch, light sockets, light assembly...
Sounds like the relay is burning out. When the lights stop flashing does the indicator on the dash light up and stay on and/or does the exterior lights light up and stay on? If the indicator light is staying on then you have a wiring problem to the lights or you have the wrong bulb/ bulbs. If the exterior lights stay on it is a bad relay or power to the relay.
Oct 31, 2010 | 1999 Dodge Caravan
Interior lights stay on
Any time something stays on that hasn't ben turned on then you should look at the relay that controls that component. The relay is stuck in the closed position and feeding power to the lights. Have the interior light relay replaced and that should fix it. Hope this helps. Good luck.
Jul 07, 2009 | 2006 Honda Ridgeline
Auto headlights staying on after turning off the car?
would be the relay sticking allowing the power to run lights even though there is no power triggering the relay would pay to get new relay and see what happens as is commin problem
Feb 02, 2009 | 1997 Ford Taurus
Relay light switch won't stay turned on
yes you are useing to much power on 1 breaker
Jan 28, 2009 | RTO 10-amp Relay Wall Switch
Interior lights do not come on
Is it an old van? Can you see on the door frame a switch does it come out when the door is opened (push in and out a few times). 3 position switch on always / off always and door switch?
Apr 10, 2017 | 1999 Ford Windstar
99 dodge caravan parking lights stay on after engine is off.
I had the same problem on my Chrysler Sebring but it was with the headlights staying on. The lights are on a relay called a "delay relay" of which will allow the lights to stay on for a minute after shutting off the ignition (after using your lights let's say when its dark). This of course helps provide light for you to see to walk to your house, keys, etc. But sometimes these relays stick on and just need to be replaced.
Dec 02, 2008 | 1996 Dodge Caravan
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
