Question about Epson Stylus Photo R1900 InkJet Printer
Http://www.fixya.com/support/t20505464-reset_counter_epson_me10_printer HOW TO RESET OF Epson ME-10 Series PRINTER.
  • 15 Answers
SOURCE: epson c59 reset
@jungi --> how to reset? step-by-step procedure? thanks..
Posted on Sep 26, 2008
  • 13 Answers
SOURCE: how to reset manualy the counter on epson d68
Manual instruction Resetter Printer Epson D68
  1. Switch on printer
  2. Open auto.bat to set the date to 19 June 2006
  3. Run adjprog.exe from the extracted folder
  4. Click accept
  5. Click particular adjustment mode
  6. Go to maintenance then Select waste ink pad counter then click ok
  7. Click on “check button till its done then click on initialization button then click on finish button
  8. witch off printer for 5 secs then switch on again
  9. After you reset succesfully, you can change the date back to normal.
Please rate my solution after reading. Thank you
Posted on Mar 05, 2009
SOURCE: my printer epson r230 is not working. the two red
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Posted on Mar 14, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
meandmatrix
SOURCE: Need to Reset Motor Counter
Here are 7 step to do:
  1. Unload all paper (Sheet and Roll). Make sure is no paper loading.
  2. Turn off the printer.
  3. Hold 3 button => Pause + Down Arrow + Menu and Turn On.
  4. Release 3 button when you see " Seft Testing 2 " on LCD.
  5. Push down go to " Clear Counter " and Press Enter (Menu Button)
  6. Push down go to " CR Motor " and Press Enter (Menu Button) mean "EXEC". Do it Twice.
  7. Turn OFF the printer and Turn ON.
The Reset is DONE.
Good Luck.
Peter Nguyen at Montreal
Posted on Jul 02, 2009
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Jan 27, 2016 | Epson PRINTER,ARTISAN 730
I have a epson stylus photo rx620. Have error message"Service required. Parts inside your printer are at the end of their servive life.see your printer documentation for details. I can not find anything in...
Epson programmed their printer to monitor the waste ink counter and your printer has reached the maximum value allowed, you have to reset your printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
Jun 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My epson r 230 printer is showing 'service required parts inside the printer are at the end of their service life' please find the solution
May 20, 2010 | Epson STYLUS R230 InkJet Photo Printer
How to fix epsonTX110 printer if the warning says the ink pads are at the end of their service life
May 12, 2010 | Epson Stylus C46 InkJet Printer
General error in r290
he maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is to replace the Waste Ink Pad/Pads with a new one/ones and then reset the Internal Waste Ink Pad Counter. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer. You can see "Exploded Parts Diagrams" of most Epson Ink Jet Printers and can also check on possible parts ordering, by Compass Micro Inc, at http://www.compassmicro.com/parts_select.cfm . Some people actually wash the ink out of the old pads, by holding them under running cold water. Then they simply dry them out and reinstall them back into their printer.
The choice on what to actually do, is yours to make. I would at least recommend getting that Waste Ink Counter reset procedure and performing it first, to make sure your printer will then work. There is an "Epson Stylus C60 Printer Information Page", that also includes the C43 series, that you can view at http://epsonhelp.freehttp.com/C60.html .
It does have a section on the left side you can click-on, titled WASTE INK PAD SERVICING and also a section titled HOUSING REMOVAL, that will be of some help to you, if you want to try the needed servicing. However, you will still need to go on-line and buy and download the actual Reset Procedure, to clear the actual Service Error Condition, if the SSC Service Utility listed below does not actually work on your model of epson printer and your computers operating system...THIS ADDITIONAL INFO MIGHT ALSO BE OF SOME HELP: Tim H 12/10/2003 2:46:24 Subject: Epson Reset Program Download Location. after a long search for a reset program for waste ink, without paying, i found it. goto: http://inkjetprinterhelp.us/sscserve.exe . please check that your printer is compatible goto: http://inkjetprinterhelp.us/epsonSSC.html .
this program has other features as well...Here's some previously posted info by NEWUSER, on that SSC Utility: Re: Epson C40+ Error and power light flashing by newuser (4/5/05 11:10 AM). To reset the error download this utility:
http://inkjetprinterhelp.us/epsonSSC.html . Once installed run the program and configure it, closing the main window and right clicking the icon in the tray area, from there choose Configure and select your printers model. After configuration, select Protection counter -> Reset protection counter, it should be able to clear the error message. If that does not actually work, then the only suggestion I can give is to perform a soft-reset before resetting counter.
Remove also the Epson status agent, it detects errors and it may hinder communication with the printer, then reboot your pc. As profile choose the one sscservice didn't use after autoconfiguration, check for printer response. Remember that you should also clean the waste ink pads located at the printer bottom, for a step by step guide download the service manual for your printer from this site
Unfortunatly, that "SSC Service Utility" does not work on all Epson Printers and not on all Operating Systems and sometimes will not even work on actually listed printer models, so you will have to check it out for yourself. Just in case that source does not work: You may actually need to go on-line to try and locate a "SERVICE MANUAL" and or the actual "RESET PROCEDURE", to buy and download for reference in disassembly, troubleshooting and servicing. I have not checked, but you can normally find Service Manuals & Reset Procedures for most Epson Printers
Mar 30, 2010 | Epson Stylus Photo R320 InkJet Printer
ERROR MESSAGE EPSON 925
Feb 27, 2010 | Epson Stylus Photo 925 InkJet Printer
Epson 830u displays this message and middle button red light flashes! Do you have any ideas? John Parts inside your printer are at the end of their service life. Contact your dealer for replacement
Jan 27, 2010 | Epson Stylus 830U InkJet Photo Printer
T11 Counter Reset
SSCLG can not counter reset the new T Series printers... please check
http://inksystem.vacqum.com
There is an adjustment program for T11 you can download..
follow the readme file and you are good to go
Sep 11, 2009 | Epson Office Equipment & Supplies
Both red light blinks even after I changed the ink
You can use SSC Service Utility to reset the counters yourself.
Download this prog.
http://www.ssclg.com/epsone.shtml
This is what your local pc shop will probably use ... it's freeware and works wonders !
Feb 27, 2008 | Epson Stylus Photo R220 InkJet Printer
C43sx both lights on
If your PC is connecting to it normally (no connection errors), it sounds like you printer is having the service reset hardware problem. Try installing the EPSON reset software and check all counters and error codes.
Try this one which fixed mine:
Good luck...
Nov 15, 2007 | Epson Stylus C43SX InkJet Printer
Epson Stylus Photo R1900 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
