How to make a saddle - Computers & Internet
  • 641 Answers
Here is the sites for that question Killer.
How do you make saddle in Minecraft
Posted on May 11, 2014
V0210019
Who cares, This saddle is for looks only, its not for anyone who rides more than 100 feet. Its uncomfortable and doesn't give your legs enough room to pedal your bike
Sep 03, 2014 | Weatherbeeta Bates Momentum Saddle Bates...
Can't find a seat that doesn't cause soft tissue tears or bony areas hurt
The body position on a tri bike is cruicial not only for aerodynamics, but for comfort as well. The saddle is the usual "sore" spot for most riders who try to find a more aero tuck. Unfortunately, there is no magic saddle that takes care of everyone's problems. Human physiology differs from person to person and saddles need to fit a wide range of riders. My advice would to try to find a bicycle shop with a saddle rental program, this will allow you to test ride a saddle before purchasing one. Also, do some research on the various saddles out there. I had to try six different saddles before settling on one that is perfect. Here are some links to saddle manufacturers:
Triathlon Bike Saddle For Men amp Women Koobi PRS TRI T1 Welcome Innovative SaddleMaker Products
Mar 27, 2014 | Cycling
Move saddle forward
Undo the fixing bolts and the saddle will slide forward
Make sure to tighten it up
Mar 04, 2013 | Cannondale Cycling
How can I choose the right saddle for me?
Peter, the best saddle for you is the one that hurts the least! Firstly, you must get used to riding because NO saddle will be comfortable until you ' harden up'. Most bike shops will have loan saddles to try. These are usually a bright colour. Don't go on ANY advice from friends because all backsides are different! The one I eventually found ius actually sold as a female saddle, but no one knows! Well, they do now.
Jan 17, 2013 | Cycling
C-11a2
C11A2
Saddle exit roller
pressure/retraction
failure
• The saddle exit roller home position sensor (PS18) is not
turned ON even after the set period of time has elapsed after
the saddle exit open/close motor (M9) is energized (beginning
of pressure operation).
turned OFF even after the set period of time has elapsed after
of retraction operation).
Jan 15, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Are there different seats on bicycles for men and for women? Just got back to cycling to work and have a bike with what looks like a regular sadle, but it really hurts my ****. Its longish and thin, is it...
There are different men's and women's saddles. In general, men's pelvic structures are narrower than women's pelvic structures. (It has to do with birthing kids.) Thus, men's saddles are generally narrower than women's. A comfy saddle is the one that is right for your pelvis.
I particularly like Specialized saddles. They make saddles in a variety of widths for men and women. Along with their saddles, they also have a fitting system that uses a gel pad. You sit on the pad, then you measure the width of the depressions made by your pelvis. Then you buy the appropriate saddle.
I had a lot of trouble with pain and numbness prior to getting a Specialized saddle. When I did the measuring, I found I had a very narrow pelvic structure. (My kids have always said I was a tight a**, but I think we are talking about two different issues.)
Hope you find a saddle that fits you well.
Dec 21, 2010 | Cycling
What is the best tilt for the saddle?
SMP saddles are tricky to see the amount of tilt you have. Try this:
Place a level surface like a clipboard across the saddle tip to rear. On top of that place a small level, one with a bubble is fine. The seat should be positioned so that it is level or slightly (1 degree) nose down. This is your starting position.
from this position you can determine front and back. You should be sitting on the saddle so when riding you don't feel like you are sliding forward or backward. The exact tilt is a personal preference. but more than 3 degrees up or down and it will be very difficult to stay in position. If you can't get the saddle comfortable, you should consider having your bike Professionally Fit.
Nov 24, 2010 | Superior Modular Products Selle SMP Avant...
Not sure about buying this saddle
The saddle itself is quite well made and should last a good while with proper care and maintenance. However, three things concern me and one is that it is a saddle you are used to using. If you are used to the support of a western saddle and move to a close contact, it may be very uncomfortale until you get used to it. The second is that the horse you use it on is used to being under a close contact saddle. The third and most important is that you indicate that you ride ' all different horses and ponies '. You do not clarify if you are wishing to use one saddle on all. I do hope not as saddles are not one size fits all. The saddle must be fitted to your 'seat' and the tree width and rise must properly fit the size and shape of the horses back. If you are unfamiliar with this, I suggest you learn how to fit a saddle before buying anything.
Jan 01, 2010 | Weatherbeeta Kincade Close Contact Saddle
How to adjust saddle postions
you can loosen the bolt under the saddle, and adjust it...
for me, the best saddle position for long distance is when it's facing downwards a little bit, so that you can move your legs freely.
Oct 29, 2008 | Bravo Sports /Bike Access 1001782 Racing...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
