Question about Sewing Machines
How do you let the feed dogs down on a singer 7436?
    Problem Solver:
  • 14 Answers
The feed dog control is on the back of the sewing machine's free arm.
To see a diagram, here is a downloadable copy of the user's manual (link below). The feed dog instructions are on page 12.
http://www.singerco.com/uploads/download/1196_7436_ingenuity-manual-(usa)_efs.pdf
Hope that helps.
Posted on May 12, 2014
  • 69 Answers
SOURCE: feed dog problem.
Open the bobbin case door and there should be a lever sitting off to the right. It moves from left to right. For the feed dogs to be in the up position the lever should be to the left.
Posted on Mar 01, 2009
  • 29 Answers
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
Posted on Jul 14, 2007
SOURCE: Singer Ingenuity Mod. 7436
you can download the manual at: http://www.costco.com/images/content/misc/pdf/334599_instructions.pdf. This site is fairly stupid and won't let me cut & paste the URL so copy it carefully.
Posted on Dec 16, 2008
  • 43 Answers
SOURCE: How do I raise and lower the feed dog on my singer
On your Singer, you don't actually raise / lower the feed dog. Instead you attach a "darning plate" (which should have come with the machine) which covers the feed dogs so they do not come in contact with the fabric. See a page from the owner's manual using this link within my web site: http://www.sewvac1.com/Singer3080_Feed_Drop.pdf
Posted on May 06, 2009
  • 1116 Answers
SOURCE: how do I drop the feed dog on a singer sewing
They do not drop.
The accessories with this model include a darning plate, which is a plastic shield that snaps over the feed dogs.
If you cannot find the darning plate, poke a hole for the needle in the center of an index card and tape it over the feed dogs with blue painter's tape (does not leave a residue) and set the stitch length to zero.
Be sure to use a darning foot and lower the presser foot.
Posted on Mar 11, 2010
My feed dogs are not catching the fabric.
Likely there is a lever, button, or such to raise and lower the feed dogs. Check all the different buttons ones you have, usually on the right side of the machine -maybe at the base. Often they are not marked.
If possible you might Goodle the machine make and model and there may be a video on U tube to show specifically how to do it.
Moses
Sep 27, 2014 | Singer 7436 - INGENUITY
On my kenmore 1120 motor runs feed dogs do not move nore needle
First off make sure your bobbin winder is not enguaged, meaning in the left hand position not the right. Also check your handwheel isn't pulled out to the right which would mean your bobbin winding clutch is enguaged.
May 21, 2014 | Singer 7436 - INGENUITY
What is bobbin re-timing?
no such thing, bobbins are not timed, needles, hooks and feed dogs are timed
Mar 07, 2014 | Singer 7436 - INGENUITY
I need to adjust the feed dog higher. There is a threaded plastic stud with a metal keeper nut surrounding it. There are 2 allen wrench studs attaching the feed dog. Which one adjusts it higher?
I would not advise raising the teeth any higher unless they have dropped down, with the teeth fully up crouch down so the teeth are in your eyeline and they should only be just above the plate, if you raise them up above what they should be you are in danger of breaking the needle plate and even the teeth holder which will be expensive
Oct 26, 2013 | Singer 7436 - INGENUITY
Feed dogs will not raise, I have lifted the presser foot, pushed the feed dog lever to the raised positon and turned the handwheel till i heard the click. They still will not snap into place in the raissed...
Hello
First, lift the presser foot; next, push the feed dog lever to the raised position; finally, turn the handwheel towards you until you hear the feed dogs snap into place
If it doesn't, you will have to run a maintenance check on your feed dogs,
Unplug the machine and examine the feed dogs. The newer machines have metal feed dogs, but older models may have rubber ones, which often need replacing. Examine the feed dogs and check for damage.
Remove the throat plate, which is the covering over the feed dogs, and clean it with a soft cloth. Use a small soft brush to clean the feed dogs. Make sure to remove all lint and thread from the grooves of the teeth. Some machines have an adjustment that lowers the feed dogs for specific sewing procedures. They should be in the raised position for better viewing during the cleaning process.
Clean the area around the feed dogs with a soft brush. Compressed air is a good choice to use in the small tight areas.
Wipe down all areas with a clean, lint free cloth before replacing the throat plate.
Prepare to clean the feed dogs and all other areas that lint may accumulate on, after every project. Your sewing machine will last longer and need fewer repairs if kept clean and lint free.
Always unplug the sewing machine before any type of maintenance or cleaning.
Never use a sharp tool when cleaning the feed dogs as this may cause damage to the sewing machine.
Apr 16, 2011 | Singer 7436 - INGENUITY
My presser foot bar moves up and down, but it doesn't move the presser foot. It's a Singer
I just looked at your manual on www.singerco.com and all I can see is that maybe, your chosen stitch length is not long enough, or your feed dogs are not up. Another possibility could be tangled thread or fabric is too slippery(try some tissue paper under fabric) check your needle size. If, you misplaced your manual it is free on the above website. Good luck, sometimes machines are just being ornery.
Sep 17, 2010 | Singer 7436 - INGENUITY
Can I drop the feed dogs or where can I buy a darning plate?
Most Singer machine have a raised plkate these days, if you do not have one you will need a Singer store to get one.
Mar 05, 2010 | Singer 7436 - INGENUITY
Singer 7436 beeps - not working
Check to be sure the buttonhole lever is in the up position and the presser foot is down. Check feed dogs to be sure they are in the up position.
sewman7
May 26, 2008 | Singer 7436 - INGENUITY
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
