Question about Akai Televison & Video
Ct 2579 When I main supply made ON & start to switch on by remot control,it does not start but after few minutes then after I again try, then it start to display.so Iassume that some one capacitor getting weak.(2)when I increase volume by remot contro,up to desire level,it continuously increase infinityand at one stage tv get switch off momentariyt and then after start autometicaly(3)colour setting at normal that is at 50 level colouer does not appeared but as increase level up to 100,colour it function proparly,but now a days r,y,b.setting un evenly changes and as result ct disply some times greenes,some times redish or some times at normal all colour prparly.I suspect due to long period of 15 years the soldaring of componnent is being dried,resulting not proparly flow of signals Please explain section wise and, I C,and component details.My self is engineer so I can understand easily...
    Top Expert:
  • Akai Master
  • 74,617 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Mar 11, 2017
techman
  • 3130 Answers
SOURCE: Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Posted on Jun 14, 2006
  • 556 Answers
SOURCE: Grundig Super Colour TV Serie F 3016 - lack of responce from remote control.
Tell me if there is a battery within this TV set which will require replacement to solve this problem
no there is no battary in tv.
The set works OK otherwise using its own control panel to change channels and its on/off switch to turn it on and off.
your statements itself says that there is no problem in tv.
in my opinion problem is in  remote only.
please try
www.remotes.com
for further help in remote.
hope this will help.
good luck.
Posted on Oct 15, 2007
chrispurs1
  • 372 Answers
SOURCE: Samsung TV
Hi.
Just read your list of problems The first fault (Diagonal lines & picture collapse from left & right) Sounded like either A poor connection or dry solder joint either on scan coils or scan coil plug / socket on main pcb.
If this were the case the engineer that called out should have spotted this & sorted it very easily. But you say it is still the same so what did he do ?
Did he give you a reciept with break down of what he did ? If yes please post it here for me to go over.
The sound problem you describe has thrown me a little so could you please post your tv model number on this page so I can see if this is a stock fault.
The static shocks you are getting is relatively normal & not a problem unless you are getting them off of speaker grilles or even tv casing if it is silver in colour.
I am UK based & have access to samsung technical but I will need your tv model number.
http://dysonmanuals.inc.io/
Chris.
Posted on Oct 30, 2007
SOURCE: MITSUBISHI CRT TV MODEL CT-33AC2SL
check for dry joints in power supply
Posted on May 09, 2008
SOURCE: Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
Posted on Jun 17, 2008
Our Toshiba CT-90325 keeps turning off by itself after 10 minutes. Can I fix this?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 12, 2015 | Toshiba Original CT-90325 TV Remote...
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Hello
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
OK.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
First green light light blinking continiously when switch on,no respond when press any remote control button's,indoor cannot start at all
dear sir
i think its an micro controlling unit problem for solve this problem please make air conditioner,s main supply switch turn off and after two minutes again turn on for reset of micro controller system . i hope after that it will work .
hope answer the question
thank you
please vote!
Oct 02, 2010 | Heating & Cooling
I have a panasonic tv, it is turning off by itself. Affter a few minutes it turns on by itself again, then turn off. What should I do?
Check the setup timer on the tv (sleep timer). Also check the remote control. There might also be a problem with the power supply. Plug it directly to the wall jack (check voltage). You should let this be checked up by a local electronics/video technician in your area.
Nov 08, 2009 | Panasonic CT-36HL43 36" TV
I have a Viewpia LC-32IE21H which does not want to switch on.
For a three years old set, first place to look is the main power supply capacitors, at least the 5vdc standby circuit is working, the problem can be as bad as the main controller board, but look at the power supply first.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Televison & Video
I have an Acer Aspire 5672, it just cut out & wont power up at all, Battery okay & power supply from mains ok (been tested). It just switched off & wont boot up again. Battery is charged &...
One thing you might try is to unplug it from the adapter and remove the battery. Let it sit a few minutes and replace the battery and try to start it again.
If that doesn't work, then plug it in and try it again.
If it still won't power up, you are probably looking at a motherboard that has gone bad. If it is still in warranty, then the company should fix it.
Nov 06, 2009 | Acer Aspire™ T180 PC Desktop
The remote control for my digital set top box,has stopped working i have changed the batteries to no avail.could you help.
Have you tried to unplug your set top box from the mains electric supply, leave it unplugged for about one minute & then power the box back up & then try the remote control. Sometimes the box can lock up & cause problems like this.
Jul 12, 2009 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
