Question about Freezers
The compressor on my Kenmore chest ffreezer is really hot and sounds like It is running but not running right
  • 957 Answers
First question would be is the fan condenser fan running or is it dead. if it is not running then the compressor will overheat.
Posted on May 11, 2014
hotuna
  • 288 Answers
SOURCE: Chest freezer
Make sure you have power going to the unit. Check the thermostat for power on both sides going in and coming out. You need to give me more info. before I can suggest anything else.
Posted on Dec 23, 2007
MNTECH
  • 1543 Answers
SOURCE: kenmore chest freezer
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Posted on Jan 02, 2010
  • 1218 Answers
SOURCE: compressor doesn't sound as if it is
Good day,
Sorry, no reset but if the compressor is not running, it could be the thermostat as well. You will need a VOM meter to check to see if power is reaching the compressor.
If it is, it could be the compressor overload protector, the compressor start relay, which are both under a cover on the side of the compressor.
Posted on Jan 27, 2010
jumptrout51
  • 3361 Answers
SOURCE: my kenmore 19.7 cu.ft. chest freezer is not
Place a volt meter set for amp draw around one wire of the compressor. If you do not have a constant amp draw replace the start relay on the compressor.
If you do have a constant amp draw the compressor is bad or you have a refrigerant leak.
Posted on Apr 25, 2010
Testimonial: "Thanks 4 the help. told me what i needeto know"
TheMobilian
  • 8220 Answers
SOURCE: I have a kenmore chest freezer that got water on
Water musta got into the compressor relay. Probably looks like this inside now:
Posted on Oct 26, 2011
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
My kenmore 19.7 cu.ft. chest freezer is not running and the compressor is hot
Apr 25, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
I replaced the thermostat on my Kemore chest freezer, but I still don't here the compressor functioning. What else can I trouble shoot?
try and check on the connection on the compressor and after that on it and if really the connection is right the freezer is gonna work.
Apr 08, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Compressor click
Possibly. However it sounds like the compressor is running hot which could be the relay assembly sticking with the start windings in the circuit.
Eric
Jan 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Chest freezer motor runs but the inside doesn't get cold
Sounds like you have a bad compressor or it has lost the gas charge.
Aug 05, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Kenmore Chest Freezer
Believe it or not, but it is normal. Especially when just turned on. As the internal temp. gets colder so will the temp. on the side get cooler.
Apr 20, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
15 cu. ft. chest freezer
Remove the back panel, if there is one, find the compressor. Put your hand on it. If its very hot, you have a problem. You should feel a slight vibration if good and running. If The overload is shutting off keep your hand there and wait a few minutes, see if there is a clicking noise coming from the compressor. This is just a start, but you said it has been off for a while so my first suspect is a compressor. Do these things and let me know for a follow up.
Dec 20, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
74 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
