Question about Singer Sewing Machines
Singer sewing machine repair manual
Crankshaft will turn [rock from one way to the other] but the needle shaft will not move more than a 2mm in either direction. Any ideas?
    New Friend:
  • 185 Answers
Depending on model my first guess would be the gear from upper main shaft (horizontal) or the gear from Vertical shaft is broken
Posted on Dec 29, 2014
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
  • 43 Answers
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
Posted on May 06, 2009
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
Machine won't sew
they do have a belt that breaks .I would suggest a repair shop visit
Dec 12, 2015 | Singer One Plus Computerized Sewing...
Needle shaft stuck. Machine won't work.
It's possible that you have threads wound somewhere inside the machine. Likely places are the tension unit and near the hand wheel.
Sep 17, 2015 | Singer 6038 Mechanical Sewing Machine
How do I adjust needle depth on my Singer 590 c?
There is an Allen screw on the shaft of the needle bar that you can loosen to be able to adjust the height of the needle. Some machines also have markings as to where the needle height needs to be. If you still have trouble talk to the people at the link below. They may be able to help. good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Nov 23, 2014 | Singer CG-590 Commercial Grade Sewing...
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Needle and take-up lever don't move when I push the pedal
It's possible there's a part loose or broken only a sewing machine repair shop can tell what's wrong
Feb 02, 2012 | Singer Sewing Machines
My Singer Prelude machine
Hi Jos, I'm no pro but I fix lots of things. It sounds like there is a mechanical blockage that is preventing the motor from turning. If you haven't already, open all the panels or covers that reveal the mechanical workings, and remove any bobbins (and maybe the needle, if the tip is touching another part of the machine) using your hand to gently rock the motor forward and backward (unplug the cord first) look for the parts to move however slightly they may be moving. if they move with your rocking motion and stop hard, there is something that has moved out of place. Closely watch the needle tip first to see how it moves and that it and its clamp are not bumping into anything. following up the shaft, gradually and methodically look at the next parts that you can see moving, and continue checking every consecutive piece in the mech, till you've come to the back end of the motor. if you havent found the culprit by now, at least you have narrowed down the possibilities and you know your toy much better that most people. When you take it to the service man, be sure to tell him how you examined it and every thing you have learned. By giving the repairer this head start, you not only reduce their time to fix it but...they will know that you are fully aware of your machine and understand something of the problem and about troubleshooting your sewing machine. You will probably fix it yourself but if not, you wont be overcharged by anyone.
Good luck, I hope this helps.
If you want, you can E me at
derbyboab AT gmail.com
Nov 17, 2011 | Singer 8280 Mechanical Sewing Machine
Old singer sewing machine (306k) motor works,belt o.k. but drive to needle is very stiff needle barely moves / peter
Apply a little singer machine oil to each of the holes along the top and in the working area next to needleplate.........rock handwheel gently and make several full rotations in each direction ......... keep at the rocking and rolling periodically over several hours if necessary....it should come good after a little patience and persistence. Do not apply too much oil, it will only make a mess. NOTE: Belt needs a little give to prevent motor overload, so do not overtighten.
Sep 08, 2009 | Sewing Machines
I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Aug 20, 2009 | Sewing Machines
Singer zig-zag 437
loosen the screw on the larger of the two feed gears (not bevel gears). Retigten so that the feed teeth start to rise right when the needle starts to rise and fall right when the needle starts to go into the fabric. Make the setting the same. i.e. when the feed teeth start to rise, how high is the needle (2mm, 3mm, etc.)? set the feed timing so the teeth rise and fall with the needle at the same height going in and coming out, this assures that the fabric only feeds when the needle is out of the fabric.
kent
Mar 18, 2009 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
66 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
