Question about Kitchen Ranges
Can You Change A Cannon Chichester Gas Range Model No 10578G From Natural Gas To Lpg Gas In New Zealand ( not in manual)
    Problem Solver:
  • 10 Answers
If it's duel fuel ie electric ovens then yes . If it has gas ovens then it's not worth doing as the ffd's will require replacing as well as the injectors and bypass screws
Posted on Jun 16, 2014
I need to change valve from LPG to Natural Gas how to disassemble front of oven
Are you converting a range from LP to natural? If that's the case, you don't change the gas valve. In the installation manual there will be detailed instructions on how to convert. Good luck!
Jan 29, 2016 | Kitchen Ranges
Is model no. GFC101W0 propane or natural gas
the difference between natural and lpg is the jet size and it would not be cost effective to produce specific models when all that is required is a change of jets
there may be a stick on tag on the back which states it if is lpg or natural gas but I suggest that because it is gas that you have a gas fitter come in and inspect it
Oct 14, 2015 | Kitchen Ranges
Rangemaster 110 on lpg wish to convert to natural gas
You must get a tradesman or technician who is qualified to convert a gas appliance, your local gas fitter or plumber should be able to help with this. the regulator needs to be changed the jets also need to be swapped out for the type of gas to be used. normally from lpg to Natural gas the jet size needs to be increased by installing new jets or by drilling out the old ones
Hope that helped
Oct 22, 2013 | Rangemaster 110 (Gas) Kitchen Range
Adjust natural gas to lpg
You need a new orifice - the store you bought the appliance from should have the kit. DO NOT use lp with a natural gas orifice - you will get a huge flame!
Dec 18, 2012 | Premier SCK 1000 Kitchen Range
What are the conversion rates from gas to lpg for our Prima LPR851 Hob? so we can fit our kit
wat gas?natural to LPG call the service center of the unit to buy an injectors nozzle want u want(LPG to natural or Natural to LPG)tell the model of ur unit.
Sep 08, 2009 | Cooktops
What is required to convert an LPG Rinnai 1001 to natural gas
Its complicated to convert. Get a qualified gasfitter to do it. The part number to convert LPG to Nat Gas is R1911 (at least it is here in New Zealand)
Jun 14, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Can you convert any natural gas hobs to LPG?
They are convertible. Most come with converting parts attached to the interior of the range.
Feb 21, 2009 | Stoves 1200DFa Dual Fuel (Electric and...
Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Jan 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
