Question about Measuring Tools & Sensors
My 1 yr. old mower will not remain running, cuts off after a few seconds and is hard to start
I have cleaned the air filter - not the problem; I have a can of carb cleaner but cannot locate the manual so I do not know where it is to do this. Thank you.
  • 957 Answers
The air filter is connected to the carb. when you take it off you should see the carb.
Posted on May 11, 2014
  • 3 Answers
SOURCE: B&S engine backfires, runs better with choke 1/2 out under load??
Check your rockers inside valve covers. They some time work loose. If they are loose the push rod will fall off rocker and cause the problem.
Posted on May 31, 2009
joecoolvette
  • 5660 Answers
SOURCE: my 13hp honda generator won't run.I have cleaned
You cleaned the fuel bowl? Was there any dirt, etc, in it? How does the fuel line look? How about the bottom of the fuel tank? How old is the fuel?
From your description, it 'sounds' like a fuel system problem. If it's a Honda EU3000is, it has Electronic Ignition, and electronic ignition usually just goes out all the way, not slowly.
The fuel line is small, and easily obstructed. Does fuel flow when the fuel line is removed from the carburetor? After the generator starts, runs, then dies, remove the float bowl. How much gas is present?
Observe the float. See if it's in good repair.
Check the float needle. See if the rubber (Neoprene) tip is squished, or is still in good shape.
Could be that when gas fills the float bowl, the float raises, then gets stuck in the up position, cutting off the gas flow.
Posted on Aug 31, 2009
Testimonial: "thank you very much for your help,most greatful.The Gen Set is at my farm and I will "attack' it this week and let you know how I go.thanks again."
  • 3 Answers
SOURCE: 3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Posted on Apr 16, 2010
  • 48 Answers
SOURCE: oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Posted on Apr 22, 2010
  • 760 Answers
SOURCE: I have a sears lawn tractor with a 25 hp ohv
So have you actually checked spark to both plugs? If so then inspect valves to be sure valves are operating. Sounds like running on one cylinder. A quick check would be to unplug one spark plug at a time. You may find if you remove the dead plugh wire, there is no change. If you unplug the running cylinder it probably won't start. Sometimes the compression release mechanisms can come apart or come loose. Download your manual for you engine model at www.briggsandstratton.com
Posted on Aug 10, 2010
My 2 yr. old Poulan Pro BVM200FE blower won't start. It will turn over a few times after 3-4 pulls then nothing.
replace the spark plug, make sure the air filter is clean, make sure it has fresh fuel. if it still wont start. give a shot of carburetor cleaner straight in the carburetor it should start and run for a few seconds. if it does. the carburetor needs to be cleaned. hope this fixes your problem, good luck
Aug 14, 2015 | Poulan Pro 25cc 2-Cycle Gas Blower...
My mower was running fine it started to lose power and run about half throttle now it want run put chock on it run a second then quits
Hi Bobby:
I'd probably tend to give it a maintenance "once over"
- Change plug(s)
- change oil (and filter)
- flush carb (check fuel filter)
- fresh gas
- clean air filter
- clean underside of mower deck
See how it runs and we'll help with any remaining problems.
May 13, 2015 | Garden
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
How do I make my lawn mower run better?
Yes, clean the air filter if it's a foam , washable fliter. If it's not the washable kind , replace it. Also replace the gas filter if there's one on the engine. Buy a can or bottle of carburetor and fuel system cleaner and put it in the gas tank to clean the carburetor.
Jun 10, 2014 | Mtd 22" Yard Machine Push Mower
Mower will start when choke is primed, however will not remain running for more than a few seconds. Have replaced gas, air filter and cleaned carburator. Still same results
Either your carb is not as clean as you think it is or maybe fuel air mixture is no good. Did you try adjusting needle valves on carb? Good Luck...
Aug 30, 2011 | Craftsman Garden
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Toro self propelled wont rev up
sounds like the govern spring came off
May 12, 2009 | Garden
Hard to start, when it does start only runs for a few seconds.
You need a full tuneup which means after the spark plug you need to do all of these and you will have a good running mower.
Drain gas tank.
Take carburetor off and clean it.
Pull the top off the engine and clean the flywhee maginets and the coil face with a small wire brush of emery cloth.
Clean screen in gas tank if there is one.
Fuel filter if the is one.
Be sure to check for a good spark after all this is done.
If this is all done you should have a good running mower.
donnyb60
Mar 20, 2009 | Garden
Measuring Tools & Sensors Logo
41 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
