Question about Pool & Spa
Strong spa brand new tried to turn on first time error code came up cfe how can I fix this
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Sounds like air pocket try to force water into jets if you have an air pocket it will error out
Posted on Jun 10, 2014
E90 Error,How do I fix or clear the E90 error I am getting on my spa?
What should I do if code E90 appears on - Intex ' Frequently ...
www.intexcorp.nl/faqsup/pub/FaqSupportServlet?action...
Jan 19, 2015 - What should I do if code E90 appears on my air bubble spa control panel? ... If alarm code E90 is displayed on the control panel, it means no ...
Oct 14, 2015 | Pool & Spa
How do you fix error code E90 in my intex spure spa pump?
You have an owners manual I hope, with
the codes & trouble charts
I would say call the pool & spa store & have
someone trouble shoot the problem
Nov 10, 2014 | Pool & Spa
E96 on intex spa pump
I do not know what that error code is however I can tell you most of those kinds of spa take around 24 hours to heat up.
What model name of Intex Spa do you have?
Rod
US Parts Center
Apr 12, 2014 | Intex Pool & Spa
Code so when runs keep shuting off then over heat code so
not too familiar with that brand. If so is error for overheat check filters or run it without. filters could be clogged and is a common cause of overheat error code. Check circulation pump and make sure its working. Also if you recently drained and refilled you could have created a air lock that doesn't allow the pump to move water and its easily fixed by loosening the discharge end of the pump until the air comes out....you will notice it right away
Sep 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa quip hot tub error code 07 stuck relay
Bad relay on the circuit board will require a new circuit board.
Rod
US Parts Center
Apr 17, 2013 | Pool & Spa
I HAVE A MONARCH SPA AND AN ERROR CODE HAS COME UP ER3
What is the brand of equipment in your spa? From knowing the brand of equipment we can search the error codes and let you know what is going on.
Rod
US Parts Center
Jan 16, 2013 | Pool & Spa
We have a brand new Oasis Mohave spa and we wanted to run through a full cycle so we ran the tub for a week, no problems. then we drained and refilled the tub. Now we get dr or dy as error codes on the...
The dr error code is for "dry". Meaning that the control system is not sensing that water is flowing through the heating element.
With a new spa, and you just having drained it , it is probably an air locked pump.
What this means is that you have a small constant circulation pump with not much power, that got ait trapped in it when you drained. When you went to start back up, this "air lock" prevented the pump from fully priming.
Power down the spa at the breaker. Remove the filter element.Stick a garden hose with lots of pressure into the skimmer hole and open the hose valve to let water inject into the skimmer.
Restore power to the spa and check operation.
If after attempting this a few times you still get the code, there is an issue with your flowswitch, or with your circulation pump.
With a brand new spa, id like to hope that you just have an air lock.
Good luck
Mar 16, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
Dream Maker Hot tub - Display is blank - no #'s - flashes 4 times
Hard to say without being there. Two things to check though. First be sure the new board is the correct one. Many times parts will change and replacements will have special instructions for retrofitting.
The other thing to check is be very sure the plug on the new board lines up with the receptor. On a multi pin plug if the pins don't line up you can get just the problem you describe. I hope this helps, sorry it can't be more.
Feb 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
49 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
