Question about Yamaha RX-V430 Receiver
Where are internal fuses as have no power when plugged in?
    Scholar:
    New Friend:
  • 54 Answers
There are several types of internal fuses. sounds like the ones you are looking for are related to providing power to your unit. IF you open up the chassis and follow where the power cord attaches - it will lead you to the power supply board where there are often removable fuses that protect the internals for power surges. Some components actually have these fuses accessible from the outside either integral to where the removable chassis power cord connects or in a fuse holder that unscrews.
Make sure you replace with the same type of fuse!
Posted on May 11, 2014
Panasonic Microwave NN-CT552W has no power - plug fuse ok - Has it got a thermal cut out or internal fuse? - Unit was ok after cooking some jacket potatoes
All microwaves has both internal thermal cut out and internal fuse, Yours problem sounds like an open 9 volts transformer that power up the front panel
Nov 07, 2014 | Microwave Ovens
Cannot locate internal fuse in my Toshiba 32DV504B
Contact any service technician. The fuse can be located at its main power supply regulator board itself. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | Toshiba Televison & Video
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
No power when plugged in
If it is new take it back or read the manual. If it is second hand, then you may want to check to see if the internal fuse is intact. These power speaker units usually have an internal fuse to back up the one in the mains connector.
Apr 19, 2013 | Pyle PPHP153MU 15 1000W Powered Speaker...
No power at all
im guessing you have opened up the case of the amplifer
look in the area where the ac plug plugs into the box.
you may have to remove some of the boards to get to it
the main internal fuse should be next to the place where you attach the ac plug
also check the main wire wires that go into the main board from the power supply check for voltage
May 11, 2010 | NAD C370 2-Channel Amplifier
Old uniden cb radio. i have plugged it in and i know i'm getting power through the cigarette lighter, but no power when i turn on the radio. no lights, no sound, nothing. please help. any ideas?
Hello there
There is a internal fuse on the inside of the unit that might need to be replaced and also check the fuse that is in the power cord ok?
best regards michel
Sep 14, 2009 | Uniden Radio Communications
Ok , I replaced the fuse checked all connections and checked plug for power ! Still my lg lmv1630st will not show any power at all . What gives?
by replacing the fuse you meant the house circuit fuse or the microwaves internal fuse? and by conncetions your talking the internal wiring inside the case of the unit or wiring from the plug? if not its your 15 or 20 amp ceramic fuse inside the unit,if thats blown replace,but chk h.v.diode,v.v. cap,triac,control board, mis-adjusted interlock safety door switch,and lastly the mag could be defective
Aug 15, 2009 | LG Over-the-Range Microwave
IS THERE AN INTERNAL BREAKER OR FUSE INSIDE A MAYTAG wc202
There is no fuse in this unit.
If unit has power but it is not cycling, then test wirings and circuit board.
Try first unplugging and plugging back the unit.
If there is no power at all , and the machine gives no sign of life, test the power cord and and the control assembly. In UK and other country there is also a fuse inside the power cord plug.
Here you find all diagrams and parts for your appliance <Click to open>.
Mar 15, 2009 | Dishwashers
NO power, no lights, possibly there was a flash before it went of
The internal fuse is normally located very near the power plug socket and usually a Buss glass fuse, rated 5 amps? If you get to it, check the metal end for the rating.You have to remove the top cover to get at it...remember, the problem could be the fuse--or the power supply section has failed.--Rick
Feb 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
Yamaha RX-V430 Receiver Logo
103 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
