Question about Craftsman GT 5000 26 HP54" Garden Tractor ()
Why does GT5000 stall when brake is released?
Already replaced seat switch and PTO any suggestions.
  • Craftsman Master
  • 2,478 Answers
Brake taking a while to release.
Posted on May 11, 2014
5 Suggested Answers
bbreton
  • 437 Answers
SOURCE: garden tractor shuts down when you PTO on or release brake
You have a safety switch or a relay malfunctioning. Try going to www.partsdirect.com, this is sears website. Look at the diagram to see how many safety switch on this unit. You may get lucky and replace one or you may have to replace all. I would look to see if it has a safety relay first, try replacing that first.
Posted on Sep 30, 2009
  • 33 Answers
SOURCE: craftsman lt1750 with kohler cv491 engine. I have
start solenoid def will it start if you jump it off by placeing the red possitive to the starter cable lug. the solenoid is about 15 dollars.
Posted on Aug 31, 2010
richroth
  • 9472 Answers
SOURCE: When the PTO switch is engaged the motor shuts
Be sure to check the back end of the seat switch wiring for loose or shorted wires. If the engine is shutting off when the brake pedal is released or the pto is engaged most likely the seat switch has failed. The seat switch connector has a shunt built into it. If the connector is not firmly plugged on the seat switch, it grounds out and when the clutch is released or the deck is engaged, the engine will die. Look closely at the connector and you will see a plunger that is pushed in when it is plugged on the seat switch. If the connector is on the seat switch securely, either the seat switch or the connector might be shorted internally. You need a meter to test this. The seat switch should read open when pushed. I hope this is helpful.
Posted on Aug 26, 2011
SOURCE: Engine starts fine but lt 2000 dies when
Hi well what you need to do is check all parts properly, you need to check the carburetor, the spark plug, coil, etc, and see if any of those are no good? When a motor does this is is usually a problem with the fuel, the spark or the coil, lead etc, or if it has electronic ignition, this maybe the problem.
However to even attempt a DIY repair one simply MUST somehow obtain a service manual, either contact the manufacturer direct or Google for one, then perform the troubleshooting steps to isolate and hopefully repair the unit.
It may indeed be best though to contact a professional who deals exclusively with this brand and ask them for a "Quote" as to what's wrong and prospective costings and go from there.
Posted on Oct 11, 2011
My craftsman ZTS 6000 dies when I take the parking brake off. It has just started doing this. Which part do I replace?
It is most likely the driver presence switch located under the seat. If the tractor has the brake set it will start and run without the driver in the seat. (PTO-off)
Releasing the brake requires a driver of sufficient weight to be in the seat for the tractor to continue to run. If the switch is defective the tractor even with driver inplace will stall. The PTO (mower deck must not be engaged).
Hope this helps?
Oct 30, 2016 | Craftsman Garden
I have already checked seat safety switches-good. When tractor is running and brake released stops running, why? Also I have checked PTO switch-good.
Hi Dawn, Does your mower have a safety switch on the brake... The links below are YouTube videos that might get you out of trouble...The 1st video is a craftsman mower that stalls out after driving off..... Also there's videos down the right side of the links that may help as well....... I hope they help......... CHEERS...
shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 28, 2016 | Garden
Why does tractor stall when brake released?
Sounds like a safety switch is shutting down your mower make sure your pto switch/handle is not engaged and check your seat switch to make sure its hooked up.
My riding lawnmower engine dies everytime i release the brake pedal
Id say that even though you say the operator seat switch "looks" ok the symptom you describe is a perfect match to a defective seat switch and or wiring
Nov 09, 2015 | Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
Motor dies when brake released
try pto safty switch
Sep 08, 2014 | Garden
L130 John Deere PTO problems
you have a bad seat switch
Sep 21, 2012 | John Deere Garden
When the PTO switch is engaged the motor shuts down the same thing happens when the clutch is let out . I have replaced all the safety switches once before and that solved the problem. I replaced the PTO...
Aug 26, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I went to go mow the lawn for the first time this season. Tractor started right up. took the deck cleaned and greased it. Went to engage the p.t.o. for the mower and the tractor stalled. Can't figure...
Hi and welcome to FixYa, I am Kelly.
The power sequence for engaging the blade deck is. Clutch brake pedal depressed, operator in seat, Enage selected and brake pedal released. When the blade enages the engine igniton kill wire is routed through the seat switch AND the PTO clutch. If either the PTO Clutch or the seat switch has a problem the engine dies. Same goes for the clutch brake pedal switch... if the clutch brake is not coming all the way up the engine will die.
If you respond with a model number (example LX2000) I can show via a manual where you need to troubleshoot using a meter.
Do a couple of good bounces on the seat, check the clutch brake pedal switch for clicks and then attempt to an engagement.
Also inspect the PTO clutch wires and connectors for corrosion.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | Garden
Craftsman GT 5000 26 HP54" Garden Tractor () Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
