Question about Baby Gear
Stuck seatbelt locking mechanism in back seat of Nissan Tida
Seatbelt won't pull out as locking mechanism stuck. Need to refit child seat into Nissan Tida
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 98 Answers
I strongly suggest replace if driving children if jamming
Posted on May 12, 2014
  • 6 Answers
SOURCE: Moving of seat belt to a higher level
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Posted on Jun 14, 2009
SOURCE: Maxi-Cosi Tobi Straps not working
I guess that you have perhaps solved your problem now but if not, have you seen this?
http://maxicosi.com/tobi/default.aspx
Hope this helps.
Chris
Posted on Apr 29, 2009
SOURCE: trying to adjust the child seatbelt harness higher in the carseat
I located my instruction manual for this carseat. It instructed me to turn the carseat over & located on the bottom are two metal brackets that lock the seatbelt harness. You just have to detach each metal bracket & pull through the bottom slots of the carseat, readjust each seatbelt to whatever level is necessary & push back through the bottom of the seat to lock securely. Thanks anyway for your help!
Posted on Apr 13, 2009
  • 3 Answers
SOURCE: fitting cabriofix car seat with seatbelt only
yeah i had a cabrio and just fitted it in car with the seat belt the part of the seat belt that would go around your waist goes over the front of the carseat and over were the baby would be sitting there is clips at either side just below the carryhandle put the seat belt through them then put the part of the seat belt that would go around your neck round the back there should be another clip in the middle of the back above the storage part if you put the seat belt throgh it then clip the buckle in and pull tight the car seat should be secure hope i explained it easy to follow.
Posted on Nov 03, 2008
  • 6 Answers
SOURCE: Rear Facing Installation
That is the common installation process for a convertible carseat in rear-facing position. It is important that the shoulder/lap seatbelt be as tight as possible. This can best be achieved by putting as much of your own weight as possible on the carseat (without the baby of course), clicking into the seatbelt fastener and then pulling as much slack as possible out of the seatbelt strap. If you have the assistance of another adult, one should provide the weight on the carseat from inside the vehicle while the other pulls on the seatbelt strap from outside to remove as much slack as possible. If you have an I-shaped locking bracket, it should be installed over both straps 1 inch from the seatbelt fastener.
Some, but not all, manufacturers provide a metal locking bracket to be placed on the seat belt after the carseat is installed to prevent excessive slippage. You could contact your manufacturer to see if one should have been provided or you may purchase one at most major baby product retailers.
Be aware, a little movement of the installed carseat is considered normal and acceptable.
One last note, many fire stations, police stations, children's hospitals and even car dealerships offer free carseat safety checks. Call those in your area and ask if they offer this service.
~Alkara
Posted on Mar 10, 2008
My 2016 nissan sentra middle rear seat belt is stuck in the retracted position. I can't use the seatbelt. how do I get it to release?
The likely cause is a broken spring/mechanism in the belt coil. I'm sure you can get a replacement for this belt.
May 22, 2017 | Nissan Cars & Trucks
The back left seat seems to be stuck due to the locking of the middle seatbelt. Any idea on how to fix that?
When a seatbelt locks up it is usually due to dirt or corrosion in the automatic locking mechanism. The mechanism can't release because it is under tension. If you get into the cover that houses the release mechanism for the seatbelt, you may be able to hit it with a little wd-40. You do have to release that tension so that the lock will spring back to the open position and allow the seatbelt to retract. Try the lube. Sometimes the galvanized coating on the internal parts causes a seize.
Apr 07, 2014 | Jeep Grand Cherokee Cars & Trucks
How can I un-stick a stuck seat belt. It worked fine last time we used it and does not seem to be twisted. 2001 chevy blazer
If it is stuck in the seat belt clip (meaning its buckled) then that model year had a seat belt buckle recall for failure. If its stuck in the seatbelt retractor and your seatbelt retractor is floor mounted there is a release pin on the ratchet gear. TO access it you will need to remove the plastic cover located at the floorboard next to the door on the side of the car that is stuck. If its a seat mounted retractor this means the retractor mechanism is located within the seat frame. You will need to view the bottom of the seat of the belt and see the anchor point. Seatbelts must be anchored to frame of car. Trace it into the seat back. If its located in the back of the seat you will need to remove the seat cover to the extent to reach the mechanism. This can be located at the bottom of the seat.. but more than likely is located at the shoulder area. The Seat cover (fabric) is removeable via clips located at the base and tucked into the seat (think hidden bra/pant clip style connectors or zipper) If you have leather seats it is a bit more detailed and more difficult to manage the seat covers. Typically your local Chevrolet dealer mechanic can get this done in 10 minutes (based one experience) and quite possibly wont charge you or charge you minimally. The downside to this is if its locked that means the same gear that locks it in an accident was frozen in place somehow and this typically indicates a dirty dirty spring or broken spring mechanism. The locking pin operates on centrifugal force and activates based on speed by which the seat belt is pulled out. (just a bit of knowledge) Good luck
Jun 15, 2010 | Cars & Trucks
Seat belt stuck on 1995 850 volvo
I solved this on my 95 volvo 850 glt as follows:
pull the seatbelt pilar cover off from the door jamb. this runs vertically up the pilar between the front an back door (beside the front seats. Once opened loosen the belt by gently pulling the belt upward toward the roof. You'll have to do this sometimes in small increments. Once the seatbelt is pulled out all the way, spray small amount of lubricant into the joint where at the top of the belt spool. Also use a screw driver to push spool upward while pulling the belt. At first it's only going to release a little but eventually the lubricant will work its way into the seam at the top of the belt spool and loosen up the stuck inertia catch. Until it completely loosens you might have to remove the pilar cover again and work the seatbelt out (also use the screw driver technique described above) in order to use the seatbelt. When parking, I would relatch the seatbelt and pull the slack up around the back of the head rest. After a day or so it worked normally.
Dec 31, 2009 | 1996 Volvo 850
Seatbelt lock reset on f-150 pick up
rear seat belts lock if you pull them out all the way and put them ALR mode. Automatic Locking Restraint. It will ratchet as the belt is rewound. This is for holding a child seat in place.
Is this your issue?
May 13, 2009 | 2004 Ford F150
Trying to adjust the child seatbelt harness higher in the carseat
Apr 09, 2009 | Evenflo Baby Gear
1998 Subaru Outback right rear seatbelt stuck.
you need to pull the belt out all the way to release it ,they have a locking mechanism for baby seats that stops them retracting,you pull them all the way out and they are reset and retract,common in modern cars,rare to give trouble
Mar 19, 2009 | Subaru Outback Cars & Trucks
Seatbelt light on
There is a tiny switch under the **** area of the seat that tells the car someone is sitting there... and a tiny switch in the seatbelt CLICK mechanism. These only have 2 wires which go down to the floor, alongside the running board and up to the dash. The switch nder your **** is NormallyOPEN and CLOSES (makes contact) when someone weighing 50lb or more sits in the seat (smart huh) It could be bent, broken, come loose from its moorings or have a wire loose... At the same time, the passenger seat also has shcu a switch and it might be STUCK or shorted. Same for the seatbelt CLICK mechanisms on both sides. If you don't like loosening seat bolts, pulling up carpeting and removing the inside panels, etc. what we call 'troubleshooting'. find someone that does - or take it to a dealer.
Jan 15, 2009 | 1999 Ford Crown Victoria
Seatbelt is stuck, can't pull out
possibly the seat belt has been pulled out all the way and the locking mechanism has been activated, if this is the case seat belt must retract all the way back in to reset this function
Aug 01, 2008 | 2005 Chevrolet Uplander
Rear passenger side seat belt is stuck, and I can't work out how to get to the mechanism without damaging the seat.
If it is a 850 sedan like mine then you'll have to remove the speaker covers and then pull up the rear deck cover, then you can get to the mechanism.
Jul 27, 2008 | 1996 Volvo 850
Baby Gear Logo
78 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
