Question about Startrac Fitness Products Star Trac 4500 Hr Treadmill Remanufactured
Lower control board red light doe not blink on star trace 4500
Why doesn't the red light on the lower control board blink on my star trace 4500TR?
  • Sportsmith LLC
    Sportsmith LLC Jul 22, 2014
    Hi Teresa Laffey, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Startrac Fit... Master
  • 918 Answers
Http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20TR4500.pdf
Posted on Jul 22, 2014
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: star trec 4500 no rpm mother board problem as all
Check the motor leads going into the L/C circuit below the MCB If you see a burnt board where the leads plug in then this is the problem if you can remove the board take it down to you local TV/ computer store and have the tech clean and hard wire and soldier the spades back. This is a common failure on this Star Trac Model
Posted on Jul 20, 2010
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
Star trac 4500 display board does not come on
You should first check the power from the wall outlet and then follow the power going into the machine -- once you find the place where the power stops, you will find the problem.
Jul 31, 2013 | Startrac Fitness Products Star Trac 4500...
My horizon treadmill immediately stops after 2 seconds
StarTrac 4500 Treadmill NO RPM Error Probable Cause A) Damaged or misaligned RPM sensor
B) Display Cable
C) MCB
D) Filter Network
Corrective Action A) Check the connection of the RPM sensor to the lower control board. Inspect RPM sensor and disc for build up of dirt, dust, or debris. Clean if necessary. Verify RPM sensor and disc are properly aligned. Units equipped with an "optical" RPM sensor (uses plastic RPM disc) should have the disc evenly spaced between the walls of the RPM sensor. Adjust if necessary. Units equipped with a magnetic "cherry" RPM sensor (uses a metal RPM disc) should have the sensor spaced 1/8" away from the flywheel. Adjust if necessary. B) Inspect the display cable for any nicks or breaks. Replace if necessary. If there is no visible damage to the display cable, wiggle the display cable to verify intermittent connection. If by wiggling the display cable, the PWM LED on the lower control board does not flash or intermittently respond, replace the display cable.
C) Refer to the NO RPM Flowchart from the service manual for MCB testing.
D) Refer to the NO RPM Flowchart from the service manual for testing of Filter Network.
Star Trac 4500 Treadmill NO RPM Error Code
Jun 28, 2012 | Startrac Fitness Products Exercise &...
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
Dishwasher control panel unresponsive
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Hopefully some of that helps!
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
No stop key indication and treadmill wont power on
Check the 2 fuses under the motor shroud. One should be a 10 Amp fuse, the other should be a 15 Amp fuse.
Is the red LED lit? If not, check outlet, check power cord for treadmill. With cord unplugged, check the connections on the motor control board for the AC input, which are marked AC1 and AC2.Plug cord back into the wall outlet, and check voltage at those terminals- it should be 90 volts or higher.
If those check out- replace Motor Control Board,
Dec 31, 2011 | Startrac Fitness Products Star Trac 4500...
Panasonic TH42PA20 - No Picture
If you have the flashing red light of death you can use the chart below to see what the blinks indicate and call Panasonic and have the part replaced, at the bottom of this page is the meaning of terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Apr 13, 2009 | Panasonic (TH-50PZ700U) Television
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Dec 19, 2008 | Philips BDS 4611 46 in. Plasma Television
Startrac Fitness Products Star Trac 4500 Hr Treadmill Remanufactured Logo
117 people viewed this question
Top Startrac Fitness Products Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Techmotionusa.com
Techmotionusa.com
Sportsmith LLC
Sportsmith LLC
Are you a Startrac Fitness Products Exercise and Fitnes Expert? Answer questions, earn points and help others
