Question about Tools & Hardware - Others
Where can i find 2 1/2 x 16 inch sanding belts retail ?
Its for a skil sand cat model 593.
    New Friend:
  • 3 Answers
  1. Amazon and MSC
Posted on Jun 25, 2014
mikeymiddles
  • 58 Answers
SOURCE: Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Posted on Jan 10, 2009
muttandjeff
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
comax
  • 154 Answers
SOURCE: Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Posted on Apr 14, 2009
  • 384 Answers
SOURCE: I have a Ryobi 4x36 Belt Sander (BD4600). I've
Look for plastic build up in the motor. Try to air blow motor and belt drive.
Posted on Jun 16, 2009
  • 672 Answers
SOURCE: sanding belt will not stay in line
There is an adjustment screw on the side of the sander that aligns the belt. Mine has a black plastic knob on it. If adjusting this does not help, remove the belt and check to see if it is making contact with the belt roller frame. The screw on mine was too long and I had to shorten it on a grinder. If you do this, take only a little at a time, a small adjustment will move the belt quite a bit.
Posted on Aug 16, 2009
I have a pressure control skil octo Sander .i think i pressed down to hard now the pressure light stays on and it won't sand but Motor runs good
The transmission between the motor and the sanding belt has been damaged by the excessive pressure you applied. Check it carefully to see if something got bent and operation can be restored. If it is gear driven and you broke off some of the gears then .....................................
Sep 16, 2015 | Skil Tools & Hardware - Others
Where can one purchase sanding belts for a skill 593 sander 2 1/2 X 16?
Search on Amazon for 2-1/2 x 16 sanding belts and you will get a plethora of options
May 07, 2015 | Sander Tools & Hardware - Others
I have a skil sand cat 2.5 x 16" belt sander model 593 no manual how do I put on and take off sanding belt?
The people at Skil will provide the data you seek Contact them on-line via this link. https://www.skiltools.com/Parts-And-Service/Pages/Email-Us.aspx
Mar 04, 2015 | Skil Tools & Hardware - Others
Skil 593 belt sander manual required
Try the Skil website for product support. There may be a manual to download or have mailed.
Oct 21, 2013 | Skil Tools & Hardware - Others
Cannot tighten then belt on a skil 594 belt sander
Have you tried the next smaller sized belt? If you tried a 24", have you tried a 21"? ... or, if you tried a 21", have you tried an 18"? ... etc.
Aug 12, 2013 | Skil Tools & Hardware - Others
I have a Skil Belt Sander 405. I bought at a sale. How old is this sander? How can I get a belt for this sander?
http://cgi.ebay.com/4-x-21-3-4-sanding-belts-36-grit-qty-10-/310329120043?pt=Sanders_Sandblasters&hash=item48410e952b
this is the type of belt it uses (size rather) 4"x21 3/4" you can find them on ebay.
http://www.skiltools.com/en/ here is the official skil website. they can probably email you an owner's manual if you wish
hope this helps out. this one is vintage from what i understand
thanks,
mike w
Jul 07, 2011 | Skil Tools & Hardware - Others
Tools & Hardware - Others Logo
140 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
