Question about Canali Black/Brown Reversible Leather Polished Metallic Buckle Belt
Does Canali sell the gold belt buckle for the Reversible belt
Seat belt alarm goes off intermittently when driving and buckled up. When I plug the passengers belt into driver,s buckle alarm is silenced. How can I fix this
There is a problem with the buckle sensor, it a really just a ground, circuit, try cleaning the buckle and belt end with spray brake clean, do not get it on the fabric of belt or seat covers.
May 11, 2016 | 2008 Ford Mondeo 2.0
Need to know what year my Colt 45 is
To contact Colt Archive Services directly:
Phone: (800) 962-(Colt) 2658 ext. 1343
Fax: (860) 244-1439
  • Joe Canali - Historical Research Sales Coordinator - ext: 1343
  • Paul Szymaszek- Historical Research Assistant - ext. 1849
Mar 01, 2015 | Optics
How do you reverse the swiss gear reversible belt
While gently pulling the buckle away from the rest of the belt, rotate the buckle 180 degrees.
Sep 14, 2014 | Swiss Gear Mens Genuine Leather Reversible...
Broken seat belt buckle
If I had the problem I would look at a junkyard or on line at e-bay for a replacement. You will need to get the buckle and the belt that it is attached to that goes down to the floor down through the crack in the seat.
Remember the buckle receiver is made for the certain belt in the front and rear seats. I have often tried to put the wrong belt in a buckle and it would not fit. ( Example: the right belt goes in the right buckle.)
Be blessed.
Nov 08, 2013 | 2002 Nissan Xterra
What is the best belt online store?
I think this is a great store: http://www.beltmaster.com/ but you can also look for big clothing on-line stores that sell belts.
Jan 10, 2013 | Clothing Accessories
I'm looking for a truck looking buckle for my dad's belt, he is a truck driver
Check out these 2 websites:
http://www.bucklesofestes.com/trucking.htm
http://www.buckleshop.com/trucking_belt_buckles.htm
Removal and repair of 1994 suburban seat belt
What kind of problem are you having? Best solution is to replace it for an used one. Dealers don't sell replacement parts for seat belts. Find an "pull the part yourself" recycler and get the part. You will learn how to take it off in there. I believe it is 3 bolts (1 for the buckle and 2 for the belt it self). Good luck.
Dec 17, 2012 | 1994 Chevrolet Suburban
Seatbelt on passenger side want work
sounds like you have a buckle failure....this is the removal procedure...
  1. Remove the front seat.
110881806
  1. Disconnect the front safety belt buckle electrical connector.
110881807
  1. Remove the front safety belt buckle.
NOTE: The front safety belt buckle retaining bolt is part of the safety belt buckle and should not be separated.
Installation
110881808
  1. To install, reverse the removal procedure
Aug 11, 2011 | 1989 Jaguar XJ6
I have just bought a bmw car 320i 1993, i see the airbag signal is red. I don't know to turn off. Please advice me how to fix it. Thanks!
You need a scanner that plugs into the round plug under the hood. It will read out the error code and reset he light. Peake makes a tool that does this. I presume that there are other tools as well.
Any shop that works on BMWs will have such a scanner.
The two most common problems are: 1) Someone jambed the seat belt tab into the buckle crookedly while the key was on.. 2) Something heavy bounced on the passenger seat occupant sensor while the key was on.
95% of the time on an e36, nothing is really wrong, so you just reset the light and keep driving. The dealer, of course, will want to sell you a new seat belt buckle or other part. On my first e36, I got two new driver side seat belt buckles under warranty before I figured out that there was nothing really wrong with the seat belt buckles.
Feb 15, 2011 | 1996 BMW 318
Canali Black/Brown Reversible Leather Polished Metallic Buckle Belt Logo
87 people viewed this question
Top Canali Clothing Accessories Experts
Da Doc
Tom Chichester
ray gallant
Are you a Canali Clothing Accessory Expert? Answer questions, earn points and help others
