Question about Pool & Spa
I have a purex triton sand dollar 60 filter I replaced the sand and when I go to put the top back on the filter it will not go down in all the way if the o ring is bad could that cause it not to go down all the way cause when we take the o ring off it fits
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 45 Answers
First, try a RUBBER mallet and GENTLY tap the perimeter of the Valve Head Flange to seat the Valve Head into the canister tank. If that does not work, you either need a new O-ring or your canisters center tube is off center or there is too much sand UNDER the canisters internal Filter Fingers at the bottom of the tank.
Hope this helps,
Dan Osko
Osko Pool n Spa
http://www.oskopoolnspa.com
Posted on May 16, 2014
  • 74 Answers
SOURCE: i took the top off of model s180t to replace the
Would those be the screws that tighten the band that holds the top on?
Posted on Apr 24, 2009
  • 93 Answers
SOURCE: filter is shooting sand back into the water when
SOUNDS LIKE YOU ARE IN RECIRCULATE MODE TAKE HANDLE AND MOVE IT TO ALL THE POSITION TO TEST BACK WASH CYCLE ETC SAND SOULD BE FINE CHECK TO SEE IF YOU HAVE ENOUGH
Posted on Jun 19, 2009
jennerina
  • 86 Answers
SOURCE: the tank pressure is at 60
I don't have that particular brand, but it is not good that the PSI is that high. Backflush for at least 3 cycles of 60 seconds each.
example: Turn off pump, move to Backflush turn on pump for 60 seconds. Turn off pump, switch to rinse, turn on pump, run til water runs clear.
Repeat 3 cycles. If the PSI still doesn't lower, you may have broken laterals in the bottom of the sand and will need replaced.
Hope this helps. Good luck!
Posted on Jul 29, 2009
  • 8404 Answers
SOURCE: Pentair sm2-pp3 valve, triton II filter. Upon
Lots of sand? You may have a broken lateral in your filter.
To repair, you will have to remove all the sand from the tank to physically inspect.
Might you have changed the sand this year? (top 1/3 needed to be changed every 3 to 5 years normally) If you changed the sand ... did you put water in the filter tank first? If not ... there is a good possibility you broke a lateral (a small pipe with slits in it) when you put the sand into the filter.
It could be that you have too much sand in the filter. Check the owners manual for the clearance - top of sand to top of filter.
Thanks for your interest in FixYa.com
Posted on May 16, 2010
aquaman987
  • 927 Answers
SOURCE: I have a hayward SP714
Sand filters have a screen at the bottom. This screen keeps the sand from getting out because it has slits or holes that are smaller than the size of the sand grain. The slits are large enough for the water to pass. If the material breaks there are areas that are large enough to allow the sand to pass and this won't stop until you replace the strainer elements.
In order to do this, you must remove the sand, remove and inspect the strainer and replace the sand.
Bring your model to a local pool supplier, confirm what I am saying, make sure they have the necessary parts and go from there.
Gary
Posted on Feb 26, 2011
How to backwash purex triton fns pool
fns sounds like cartridge have to take out and clean if no backwash on a multiport
Jan 11, 2014 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
We have a purex triton metior 26" 8 position sand pool filte that leaks at the top of the tank. We have changed the "O" ring but it still leaks alot. What else can we check? Thanx
Try lubricating the o-ring with vaseline before installing. Make sure there is no sand on either of the surfaces that the o-ring touches.
Gary
May 24, 2011 | Garden
May 14, 2010 | Pool & Spa
Purex triton powermax 400- gas ignites for a moment and then shuts off - basically cycles on and off for the spa. any idea to the problem?
This is usually either the Thermal Overload Cutoff (an inline fuse to prevent overheating) which costs $13.50 through poolcenter.com, or it is that you are not getting enough water pressure through the heater. There are sensors that will shut down the heater if there is not enough water flow. Is your filter clean so enough pressure/flow is happening?
Feb 15, 2010 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Have a Triton Millivolt pool heater pilot is lit and nothing!!
Low out put voltage from the pilot generator and/or an open circuit in the control circuit...the most common is a bad pressure switch (dirty filters can hamper pressure switch operation).
Jun 08, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Pool & Spa Logo
57 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
