Question about Panasonic DMR-ES35VS
What do I do for a unit that says "incompatible disk", even when there's no disk in it?
Unit does five clicks when you turn it on and says "incompatible disk" even when there's no disk in it
  • 36 Answers
It has a very simple solution. Clean the head. (disk head) and you will be good to go Pam.
For this, purchase a DVD/CD head cleaning tool kit.
If it doesn't help let me know. If you don't know how to do it let us know. :)
Posted on May 11, 2014
How do I get my CDs out of the 6-disk changer? For a while it was saying "disk error, please eject disk", but when I pressed it clicked and whirred (a lot) and nothing came out. Now it thinks...
ill assume your still under warranty?when we install an exchange unit under warranty they take the original back to service it.they will ship us back any cds that are in unit and we in turn notify customer.usually about three week turnaround.
Mar 18, 2011 | 2009 Nissan Murano
How do I add toner to machine? Also, is this copier do color copies?
1 Open the front cover and pull out the
drum unit and toner cartridge assembly.
2 Hold down the lock lever on the left and
pull the toner cartridge out of the drum
unit.
3 Unpack the new toner cartridge. Place
the used toner cartridge into the
aluminum bag and discard it according
to local regulations.
4 Gently rock the toner cartridge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place. If you
put it in properly, the lock lever will lift
automatically.
7 Clean the primary corona wire inside the
drum unit by gently sliding the blue tab
from right to left several times. Return
the blue tab to the Home position (▼)
before reinstalling the drum unit and
8 Install the drum unit and toner cartridge
assembly in the MFC.
9 Close the front cover.
If you need illustration for this, click on the link below and turn to page 112
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Jun 02, 2009 | Brother MFC-7820N All-In-One Laser Printer
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
CD STOPPED PLAYING AT TRACK 3 AND NOW WILL NOT PLAY AT ALL. PD-65 HAS BEEN STORED (NOT USED) FOR SEVERAL YEARS APPRX 7. DOES IT NEED CLEANED
First try ejecting the disk and unplugging the unit power cord for five minutes.
if that did not work, that probably means you have a lens problem.
Use a dvd lens cleaner kit , like the ones that you see clicking here.
Ifthat does not work, you will need to take apart the unit, access thelens pickup, and clean the lens directly, using isopropyl alcohol and acotton sticks.
Oct 11, 2008 | Pioneer Audio Players & Recorders
Sharp BD-HP20U Had been working fine, until today tried number of disk both blu-ray and dvd in and during disk reading process an error msg comes up incompatible disk
I have the same problem. I started several months ago with brand new blueray disks. Now even disks that worked before, now come up as incompatible disks. I have tried contacting support thru their website and never getting a response. Not even the automated response about how blueray is always changing. No firmware upgrades since 10-29-08. I will never purchase any sharp products again. And I would advise anyone considering it, dont. What a waste of money.
Oct 06, 2008 | Televison & Video
Original Xbox Won't Let Me Copy Games
when you find the game you want to copy highlight it and push right on the controller and highlight a saved game then select it and you will be given the option to copy it.
May 13, 2008 | Microsoft Xbox Console
STUCK CD DISK
I have a Harman Kardon CD Changer. I moved the unit in prepration for installation of new carpet. I failed to remove the CD's and four of five of them jamed. I could not remove the cd's by any means and turned the unit upside down and pointing the front downward. No luck. In fact the tray jammed at this point. Do not force the tray.
Be aware removing the cover might void your warranty. If this is a concern take the unit to an approved repair location.
I un-plugged the electrical power cord from the electrical outlet and removed the cover. Place the screws in a safe place and separate them by size rembering where they came from. Be careful and do not touch any of the components inside the unit with your hands, fingers or any tool. Some comonents in electrical units can hold an electrical charge even after the unit has been turned off and unpluged from electrical outlets. Whether you unit holds an electical charge is unknown to me. Wear rubber soul shoes.
With the cover off, I saw the CD's were jammed together in the CD player (?). I sucessfully removed the CD's. Replaced the cover and screws and the unit worked.
Good luck. If you are not up to this ask a friend with mechanical abilities to do it for you.
Jan 09, 2008 | Sony DAV-DX150 System
Error??
In Windows XP, rt click my computer. Scroll down to manage and click. Find disk management on the left and click. Your player should show up as a disk drive and you should be able to formt it here.
Dec 16, 2007 | RCA OPAL M4001 MP3 Player
DVD not working
You would have to open up the unit. Likely the "clicking" is it recentering the head attempting to read the disk.
Most likely you simply have a dirty lens (how old is the unit and how much use does it see?) which could be cleaned gently with a cotton swab and rubbing alcohol.
Nov 20, 2007 | Philips 20DV6942 20 in. TV/DVD Combo
Panasonic DMR-ES35VS Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
