I have a duraband am/fm radio cas - Audio Players & Recorders
My old unit stopped working;(worked perfect for many years) so I replaced with a new same model and I have bad interference and FM static. Sometimes the FM station overrides the express radio and all you...
The very first XM radios, (SkyFi2, MyFi, Roady2) up until they were put in red boxes, had a VERY strong FM transmitter, so strong, that when Sirius was their enemy, they complained to the FCC and they made the FM transmitters real weaklings. So unless you have one of the first two batches of XM radios, the FM transmitters now are real junk and you're better off using an AUX input on the radio or a cassette tape adapter. Okay? Thanks.
Mar 26, 2015 | Audio Players & Recorders
How do you access the fm radio on a Samsung GT-C3300K please. The user manual only mentions the mp3 player. Thank you.
To listen to the FM radio
1. In Menu mode, select FM radio.
2. Select to start the FM radio.
3. Select Yes to start automatic tuning.
The radio scans and saves available stations
automatically.
The first time you turn on the FM radio, you will be
prompted to start automatic tuning.
4. Control the FM radio using the following icons
and keys:
You can find the User Manual that show the FM Radio in this link. Look on Page 25 for the Radio Instructions
Apr 21, 2011 | Samsung Cell Phones
Why are there 4 orange wires in the radio wire harness 2000 satern am/fm/cas/cd. What are they for? I understand the orange is the 12v+ do I hook up all 4?
Get a test lamp one should be hot all the time One should be hot when you turn on the key to run position One should have power when dash lights are turned on The last should be ground Good Luck
Dec 05, 2010 | 2000 Saturn Ls 4dr Sedan
In my settings there is no fm transmitter selection available
As far as I know, there is no transmitter in a Sirius Radio. I had an XM, and there was no selection for fm stations. They just figure you can tune the car radio to any fm station, in case you want to listen to fm. Hope this helps, but refer to your manual for details about what the unit can do.
Jun 12, 2010 | Sirius Sportster 5 Satellite Radio...
IBOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO...
BOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO OPTIONAL BUT NOTHING IS PLAYING FROM RADIO
Mar 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I need to buy a battery and replacement cord for my son's Duraband PDV-709
Your local Radio shack could help you with a power adapter.
Technical Specifications:
AC input voltage ……120VAC, Output ………9V 2-2.5A Up to 22W
Plug Tip size.......4.0/1.5/12mm
or
Search E-Bay for Duraband PDV-709 they have car or home adapters.
Dec 03, 2009 | Durabrand PDV-709
Needing code for radio shack 15 2147 for a duraband tv
Check this link on OwnerIQ
http://tv.manualsonline.com/ex/thread/view/idThread/57583
You may have to register to get it
Mar 09, 2009 | Radio Shack (15-2147) Remote Control
Can't set clock on my Duraband am/fm car cd player
Try Googling (durabrand)(DB1200)(manual) without parens to get information.
Apr 28, 2017 | Durabrand Car CD Player and AM/FM...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
 Grubhead
Grubhead
