Question about LG LFD22860 Stainless Steel Bottom Freezer French Door Refrigerator
LG refrigerator Ice build up in the bottom freezer
  • 711 Answers
Check the seal in the freezer, if it is leaking outside moisture can get in as well as cause things to defrost near the leak. Also make sure the contents aren't blocking the door to where the seal is leaking. If this is all OK then perhaps the fan units fan is not pulling the moisture out. It does tend to build up in most freezers a bit anyway. also
Posted on May 11, 2014
  • 36 Answers
I have a LG freezer too. It has anti ice system.
If it is a very humid day with a lot of water vapour in the atmosphere this might happen.
Or your anti ice system is off the grid. Visit the LG store.
will not take more than 20-50 USD for the repair.
  • 400 Answers
SOURCE: Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Posted on Mar 05, 2009
jeffbvegas1
  • 520 Answers
SOURCE: LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Posted on Jun 26, 2009
heatman101
  • 43501 Answers
SOURCE: why is there heavy ice
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
  • 66 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
water drain clogged !
see this page for a fix, it might suggest a fix to your frig a s well
Avi
Posted on Jan 13, 2011
  • 66 Answers
SOURCE: Water Leaking From Under LG LRFD21855 Refrigerator
yep, it looks like a frozen drain pipe. to solve it , defrost your frig for 24 hours. if that doesn't help, see the following page for details how to fix it. http://www.schneordesign.com/Avi/LG/LG819_fix.htm good luck Avi
Posted on Jan 21, 2011
Ice is forming on bottom of refrig. under the freezer bin. Suspect it is the defroating system malfunctioning. Repairable without calling an expert?
HI,CHECK IF THE FREEZER DOOR IS CLOSING PROPELY..IF HOT AIR IS GTTING INSIDE THE FREEZER WILL BE SWETTING AND BUILDING ICE.
Jul 05, 2011 | LG LRFC25750 Refrigerator French Door
My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
Ice build up
check that both cyclic defrost elements are working i dont think they are
Apr 21, 2010 | LG LBN22515 Bottom Freezer Refrigerator
My LG GR-349SQF freezer keeps getting ice in the very bottom
I believe your defrost condensate drain is blocked with ice or other foreign objects. Could you also double check the model number? Thanks, Sea breeze
Dec 29, 2009 | LG Refrigerators
LG LFX25980ST REFRIGERATOR W/BOTTOM FREEZER SHOWS MESSAGE ON DISPLAY ER IF WHAT DOES THIS MEAN
The control is not seeing a feedback signal from the ice room fan. (the fan inside the freezer which pushes cold air up to the in door icemaker) It is probably blocked with a build up of ice or frost, preventing the fan blade from turning.
Oct 20, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Loud fan - ice build up in fan compartment.
Check resistance on bi metal thermostat/heating element.Make sure continuity is present on thermostat before defrosting.Advance derost timer if analog unit.
Sep 05, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Ice build up on floor of freezer drawer
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
Jun 30, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
LG LFD22860 Stainless Steel Bottom Freezer French Door Refrigerator Logo
341 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
