I can't get my RCA 7" potable TV to pick up channels
    Problem Solver:
  • 10 Answers
In Order For Any Tv Reciever To Pickup & Scan For Channels You Must Make Sure You Have A Good Antenna & And That It Is Plugged Into The Correct Port..Go To The Set Up Menu & Follow The Instructions...
Posted on Jun 30, 2014
3 Suggested Answers
  • 135 Answers
SOURCE: television only locates 7 channels????!!!!!
Hi there!
If you cannot receive all channels it may be a fault with the antenna or the tuner may be faulty. If you have a VCR, you can tune that into the TV first and then tune the VCR to see if you then receive all channels. If so, use the VCR position on the TV to view and select or change channels on the VCR only. Good Luck,JUS004
Posted on Mar 09, 2008
nicknovikov
  • 100 Answers
SOURCE: troubleshooting w/rca colortrack 1989
tuner,eeprom.
Posted on Jun 28, 2009
Step by Step instructions on How to run set up for my RCA flat panel antenna to pick up local tv channels
connect your antena first then go to setup on the tv and selct channel search it will scan and find all the channels that you can pick up with your antenna
Aug 25, 2014 | RCA Digital Flat Panel Antenna
My rca indoor antenna will not pick any channels up on my hd flat screen tv
Signal not strong enough in your area for this indoor ant...Does it work with an outdoor ant?
Nov 29, 2013 | Televison & Video
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
My 32av502 tv was just disconnected from satellite & now I can't get the tv to work. It won't pick up any local channels & I don't know how to reprogram them in.
Processor could have some garbage in it, unplug it from the wall and leave it unplug for 40 MIN> then it will reset back to normal.
Jan 11, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
I DONT TUNING THE CHANNELS
Your problems can be solved by using the menu setup on your tv. Spanish is an option you can choose.Also on the menu you select air(antenna) or cable,then choose auto scan.The tv will pick up all channels available in you area.
Dec 20, 2008 | RCA BD20TF10 20 in. TV/DVD Combo
Channels
Hit the menu button, find and enter setup (or channels)
Choose cable or antenna (what you have)...... then make the set "autoprogram". It will add all channels into the tv memory.
Mar 25, 2008 | RCA 20F420T 20" TV
Television only locates 7 channels????!!!!!
Hi there!
Mar 07, 2008 | RCA F32649 32" TV
RCA 32" TV
The most likely problem is a stuck tact switch, if it goes up in channel number, 5, 6, 7, etc. then the channel up button is stuck, if it counts down it`s obviously the ch. down button. Problem is you have to remove the guts of the set to get at the control boards screws, you can try turning on the set and poke around the offending push button with a tooth-pick, if it stops changing channels leave it alone and use your remote from now on to change channels, if you can`t get it to stop the tact switches or the control board module will have to be swapped out, hope this helps
Nov 27, 2007 | RCA F32695BC 32" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
