Question about Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood
How to light the pilot light in a bosch aquastar 125 fx ng tankless water heater
    New Friend:
I have the same machine first they said replace the micro switch i did then rebuild the water valve did not enough gas presure had it checked revented the unit the unit is brandnew relubed the water valve idk
Posted on Sep 03, 2014
co7196
  • 3433 Answers
SOURCE: The Pilot burner flame is large & yellow
the pilot is getting too much air and is an indicaiot of dirty or air/ fuel ratio imbalance. The pilot is wimpy and the thermocoupler has alot to do with the gas . Make sure your thermocoupler is on the tip of the flame. You may end up replacing it. because it is showing signs of eminnt failure. When it fals your curners won't fire up. Good luck.
Posted on Jun 09, 2009
gary1121
  • 332 Answers
SOURCE: Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
co7196
  • 3433 Answers
SOURCE: Bosch Aquastar tankless water heater model
There should be a thermocoupler, it is that bulb that sits in the pilot flame. If it is not functioning properly the main gas valve will not open.. Hmmm, Is the main valve in the on position?
Posted on Oct 10, 2009
  • 518 Answers
SOURCE: I have a Bosch AquaStar AQ-125-BNG tankless water
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Posted on Jul 05, 2010
  • 395 Answers
SOURCE: Pilot light goes out randomly on 6 year old Bosch
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
Posted on Aug 31, 2010
I have a Bosch 125 BNG gas tankless water heater. Pilot light will not light but spark is there. Solution and where do I get parts assuming needed.
Check and be sure gas knob is in the pilot lighting position and pushed in. Try to manually light with a match. Make sure gas **** is in the on position. Posible air in the gas line. Bled off air. gas valve or regulator has failed..
Jan 04, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light goes out randomly on 6 year old Bosch Aquastar tankless water heater. When I restart it it may work for a day then goes out again.
Aug 30, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
Jul 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Bosch Aquastar 125ng with the water turbine ignition. When you turn on the water, it works exactly as expected. If you shut off the water and then turn it on again, it will not always start. It...
i have an aqua star 125 ng an the pilot lights and stays lit but the main burners wont fire up when i turn the water on i have good water pressure so i kind of stumped and i just rebuilt the diaphram in it also
Dec 11, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Can't light my Bosch 1600 P tankless water heater.
make sure gas has been purged check pilot and thermal coupling
Aug 27, 2009 | Bosch 1600P-NG Natural Gas AquaStar...
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Gas tankless water heater turns off during shower
Take the thermocouple out and match it up at any hard wear store. Maybe $10. Replace it .Make sure the flame is clean and hitting the rod in the center center. Ajust (Bend) accordingly.
Feb 23, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Jan 25, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood Logo
170 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
