How do I get my Rca 7" portable TV to pick up channels
5 Suggested Answers
  • 135 Answers
SOURCE: television only locates 7 channels????!!!!!
Hi there!
If you cannot receive all channels it may be a fault with the antenna or the tuner may be faulty. If you have a VCR, you can tune that into the TV first and then tune the VCR to see if you then receive all channels. If so, use the VCR position on the TV to view and select or change channels on the VCR only. Good Luck,JUS004
Posted on Mar 09, 2008
nicknovikov
  • 100 Answers
SOURCE: troubleshooting w/rca colortrack 1989
tuner,eeprom.
Posted on Jun 28, 2009
freetek
  • 5568 Answers
SOURCE: TV won't pick up channels 7-13
These are what once were VHF channels and are still mostly assigned to local stations.
You didn't mention the source for your received signals, if antenna, cable or satellite and it does make a difference as to the possible source of the problem.
If you are receiving via antenna, then the problem is within the set itself. If from one of the other two sources requiring a 'box,' then the problem is likely within the cable or satellite box that is between your incoming signal and the set.
Posted on Jul 29, 2012
  • 23 Answers
SOURCE: How do I program my RCA LED48G45RQ HDMI to digital channels
Several things to check. First go in the menu where u are doing the channel scan and see if there is a separate line that says digital and if so select it so it can add those channels. Next look also on the remote and see if there is a button that says ANT or Input and press it to see if selects the digital side. Next see how u are hooking up the set from either cable, SAT, Antenna, etc, and are u going thru the antenna connection/the screw on cable input. Cause if going thru hdmi or any other input will not allow u to scan channels. Next the tv may not have a digital tuner in which some new sets don't, look in owners manual and read on channel programming and it should tell u. Maybe something here will help.
Posted on Dec 09, 2014
When I did the air auto scan it only picked up two channels. How can I get more channels?
The auto scan picks up whatever channels are available, if it only picked 2 then that is all you have available
Dec 11, 2015 | Pegasus 7" ST07-B Portable Handheld...
I can't get my RCA 7" potable TV to pick up channels
In Order For Any Tv Reciever To Pickup & Scan For Channels You Must Make Sure You Have A Good Antenna & And That It Is Plugged Into The Correct Port..Go To The Set Up Menu & Follow The Instructions...
May 11, 2014 | Televison & Video
Why wont my casio tv 600 pick up eney channels
I HAVE THE SAME PROBLEM BUT LAST NIGHT I PLACED THE TV NEAR THE FREEVIEW BOX AND THE TV JUST PICKED UP THE SIGNAL.A DIGITAL CHANNEL AT THAT ASWELL.NEAR PERFECT IMAGE.I DONT KNOW HOW THIS COULD BE ADAPTED TO USE THE PORTABLE AWAY FROM OFF THE FREEVIEW BOX.ANY SUGGESTIONS?
Aug 18, 2012 | Casio Portable Hand Held Tv - Model...
I have this same model TV and I use it with as
You probably need an RF (radio frquency) modulator to be connected between the cable and the TV. Connect the cable to the ANT IN on the RF modulator and then use the TO TV outlet OR the three RCA outlets (yellow video, red left audio channel, white right video channel) to connect to the Haier portable TV
I bought two such modulators made by TriQuest at a local surplus-type store (i.e. Big Lots) for about ten bucks each.
Incidentally the TriQuest unit also has an S-video output.
Nov 16, 2009 | Haier HLT71 7 in. Portable TV
Coby tf-tv700 a 7in lcd tv will not git channals since diggital s
Go to menu pick rescan channels,not getting more channels,get digital antena.Rescan again.
Aug 15, 2009 | Coby TF-TV700 7 in. Portable Television
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Poor reception on atsc portable tv
an external or outside antenna will improve the amount of stations picked up and maybe a amplified antenna will help
but the boxes they sell seem to do better in reception even with only a rabbit ear antenna.
I use a box on my 32in LCD because the internal tuner just does not get all the channels without having to get up and move the antenna and the outside antenna , well I'm not going to go out there to move it all the time , and the amplified antenna I still have to keep getting up to move the antenna
so in all the box( "zenith","digital stream"are good , have yet to test others) works the best in recieving the digital channels without much worry of the antenna
Mar 13, 2009 | RCA 9V345T 9 in. Portable Television
How do I get it to channel 3 to use my converter box
turn on the converter box and then scan for channels on the tv. Channel 3 should be picked up by the tv as having a signal.
Mar 09, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
I DONT TUNING THE CHANNELS
Your problems can be solved by using the menu setup on your tv. Spanish is an option you can choose.Also on the menu you select air(antenna) or cable,then choose auto scan.The tv will pick up all channels available in you area.
Dec 20, 2008 | RCA BD20TF10 20 in. TV/DVD Combo
Television only locates 7 channels????!!!!!
Hi there!
Mar 07, 2008 | RCA F32649 32" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
