Question about Hampton Bay 46056 Callaway II Ceiling Fan
FAN WORKS SLOW BLADES GO SLOW - Hampton Bay 46056 Callaway II Ceiling Fan
What causes slow moving electric fan proppelers
Slow moving fan blades may be a result of gummed bushings in the motor, they need to be lubed periodically and the motor needs to turn freely.
Jun 28, 2011 | Dryers
Fan moves very slow what is the promblem?
Sounds like you need to oil the fan shaft. They get dusty and dirty and it gathers in the oil that was in it.
add more oil and it should fix the problem. THE RAZ
May 13, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
Slow desk fan
The thrust bearing or ball is worn out or missing. When you tilt it, the motor shaft spins freely. When you set it down, the shaft goes to the rear and creates drag on the motor.
Aug 31, 2009 | Dryers
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
The fan blades do not turn but the fan motor can
speed switch is no good, the one attached to the pull cord. replace
Jul 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Hi, I have an 1985 Chelsea attic fan. The motor is still working fine, and it is turning the main bolt on which the fan blades are hung. This main bolt turns very fast, at the speed of the motor. The fan...
It is the fan clutch. Like in a truck with a full time fan, it has a clutch that accelerates the fan as it is needed. Your clutch on the fan has probably burned out.
Jun 21, 2009 | Heating & Cooling
Ceiling fan
Hello Capt Treb. Turn off the power. Check all the blade and support arm mounting screws for tightness. Stand on a step stole and view the blades from a horzinal plane to check all blades have the same pitch by slowing rotating by hand. You may have to bend the arms a little to aquire an equal on the plane. To locate a weight balance is a shoot & miss with the balance weights. Good luck.
Sep 26, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 46056 Callaway II Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
