Question about GE Dishwasher Motor P/n 5kcp119efk001x
The motor got stuck after couple weeks idle. I had to unplug the power and rotate the motor fan with the scree driver to get it started. How do i fix the issue?? Where do i get parts to replace?? Thank you.
    Sergeant:
  • 304 Answers
Go to appliancepartspro.com use your model number to order a new pump motor
Posted on May 11, 2014
Soleus Air FSH-40G fan would not start. The bad seems harder to rotate. what could have gone wrong? How to fix?
First unplug the fan for safety. Next add a couple drops of motor oil on the shaft that turns with the fan blade. Tip the fan blade at about a 45 degree angle when adding the motor oil. Spin the blade by hand at that same angle to allow the motor oil to flow down the shaft, inside where you cannot see the shaft. It should start turning by hand a lot easier now.
Sep 06, 2015 | Soleus Dryers
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Freezer is not working
your evaporator fan motor may start to go slow or idling causing ice build up due to no air circulation or the compressor is overheating check your fan motor also.
Dec 16, 2013 | Refrigerators
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Heater fan stopped working
check the back of the fan switch for power and inspect it for damage ,melted or loose connections.
May 25, 2009 | 2002 Ford E350
Bike wont idle and power constantly dieing and recovering
check to see if you have gas in the oil from a carb leaking down which will cause the idle speed to drop when motor warms up.pick up idle run for awhile then plugs foul.like you said a carby problem.
Feb 16, 2009 | 2006 Honda CBF 250
Iced up Samsung RS21 JGNS Help!!
Defrost the unit and after defrosting, with the unit unplug rotate the fan blade manually using your finger. The fan should rotate freely, the blade should not touch the fan frame. Slow rotation of fan motor can cause icing. Worn out bearing, misalign fan blade, partially burn fan motor can slow the rotation of blower motor.But if the blower operate normally, then the unit may be under charge of refrigerant. Qualified technician is needed with this problem.
Mar 05, 2008 | Refrigerators
Motor not running?
There is a pump motor underneath with an impeller that is most likely stuck. You will need to turn the impeller until it breaks loose if it is stuck. This is a common problem with GE dishwashers and I recommend that you run it at least once or twice a week to avoid this problem in the future, even if you have to run it empty.
Feb 27, 2008 | GE Nautilus 24" Built-in Dishwasher
My idl 700 dishwasher hums but wont start
if this machine was sitting for a few weeks the pump seals may have dried and stuck . manually rotate motor to free it . another possible cause is oblect caught in pump
Feb 15, 2008 | Dishwashers
GE Nautilus dishwasher wont run
i am taking it to the dump... throw it in the gutter and go get another...
Nov 28, 2007 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher Motor P/n 5kcp119efk001x Logo
47 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
