Question about Avanti WDR71
Mitsubishi WD 72737
The tv starts to freeze then shuts off whenever i touch the device button on my remote or whenever I go to   Tv menu and then click on Audio/Video. the last time it worked correctly I had unplugged my Blu Ray from it ..dont know if that caused anything...
    Problem Solver:
  • 12 Answers
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Posted on Sep 03, 2010
We have a mitsubishi 735 series tv. When we power it on the mitsubishi sign comes on then the tv shuts off. We replaced the lamp bulb but that wasn't the problem. Any suggestions
Most of these sets that come on with the blue screen and logo and shut off shortly after may have two resets---I can tell you the soft reset.
Turn set on with the Mitsubishi remote and when screen comes up blue with logo:
Menu, 1,2,3 enter
This applies to most of these sets.
Mar 14, 2012 | Mitsubishi WD-60735 Projection Television
Device button is freezing my t.v.
Try this:
1) turn on the TV
Let me know if this works
Jun 26, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-62827 shuts down after pushing the device button.
With the remote press menu 2470 enter then do a system reset after the set has reinitialized this should fix your problem, you will have to reprogram your channel settings afterwards though.
Oct 17, 2009 | Mitsubishi Televison & Video
Power surge and now all we get is snow and cannot get to the Device menu remote nor button on TV lets us get device menu
There is a simple thing you can try---with set on use original Mitsubishi remote:
hit Menu, then 1, then 2, then 3 and then enter--this is reset and set will shut off and come back on channel three in the air band------There is also a Hard Reset for the whole set---try the 1,2,3, etc first.
SD TECH
Oct 14, 2009 | Mitsubishi WD-52628 52" Projection HDTV
When accessing the Device Menu, the TV turns off
I would contact Mitsubishi and see if there is s software upgrade for this model. You can contact them at 1-800-332-2119.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD52527 52" Projection HDTV
WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Jan 05, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Device Menu not working
Could have a stuck button or a corrupt e-prom, but lets try kicking this set in the head, Now these reset codes are model dependent so this code will not work for every set out there but this reset is for the WD-62525. with the set on and with the original TV remote hit the keys in this sequence, MENU-2-4-7-0 this will bring up a service menu, the cruiser should already be on "Initialize" so simply hit enter. this will reset the TV to factory defaults and may fix your problem
Sep 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Avanti WDR71 Logo
131 people viewed this question
Top Avanti Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
