Question about Air Conditioning and Heat for Mazda Tribute
How do i know what rims will fit my car?
I wanted to replace my rims on a 2006 chevy cobalt , but not sure how to find out if they will fit
  • Grace Klems
    Grace Klems May 11, 2014
    my tire size is 16 i have factory rims on now but wanted to replace them
    Problem Solver:
  • 14 Answers
Hello this is a easy one you need to get your self a set of Wheel/Stud Bolt Circle Template's they cost about $20.00 you can get a set of three which includes 5 lug SAE, 5 lug METRIC, 4 lug SAE & METRIC
all you do is count how many lugs / studs you have holding your wheels on your car select the correct 4 or 5 hole template and spin it around until the holes in the template line up now you know the correct
bolt circle. Match that with the wheel your looking at to put on your car
and you will know if it fits. Tell the person at the junk yard your bolt circle and they will know what to look for.
Good luck! and be safe.
Mark / aka RagenRat
Here is the link to the Templates
JEGS Performance Products 80863 JEGS Wheel Stud Bolt Circle Template...
how do i know what rims will fit my car? - c857ecb2-ab92-41c3-bd31-e5f5690368a2.jpg
Posted on May 12, 2014
Remove and replace an outside door handle on a 2006 Chevy colbalt?
the following quote is taken from the web site from a chevy cobalt forum. if you have any more questions they might be able to help you directly.
(all it is is 2 bolts. Just take off your door panel and pull back the protective plastic and look for 2 bolts that line up with the door handle.)
How Do You Replace The Outside Door Handle Chevy Cobalt Forum Cobalt...
Jan 30, 2015 | 2006 Chevrolet Cobalt
I have a 2006 chevy cobalt, replaced the blower motor resistor and still no heat or defoster, all the fuses are good under the hood not sure how to check the relays to see if they are bad... any...
Either the controller, where you turn on the heat. Or the blend door motor is bad. Most chevy blend door motors are Under the dash in the center, behind the console. Hard to get to, but not impossible to replace.
Jan 06, 2015 | 2006 Chevrolet Cobalt
Do you know where the low side of a chevy cobalt (2006) is ?
Normally the low pressure and High pressure lines run on the passenger side of the engine area. They are the two aluminum lines that run to the firewall from the AC compressor. The good news is the refill can you are going to use to refill your system will only fit the low side line. The fitting is most likely covered by a plastic dust cap to keep it clear.
Sep 17, 2011 | 2006 Chevrolet Cobalt
Why wont the key come out of the ignition? 2006 Chevy Cobalt. Key stuck in ignition and car will not start.
My cobalt turns over but doesnt start up and i dont know whats wrong with it to get it fixed.
May 27, 2010 | 2006 Chevrolet Cobalt
I've had the same problem with my 2006 Chevy Cobalt
my power stearing in my 2006 cobalt went out and i had to get the entire steering collem replaced. havent had a problem with it sence knock on wood!!
Jun 27, 2009 | 2006 Chevrolet Cobalt
2006 Chevy Cobalt engine is shaking real bad and car has no power
I WOULD TRY AND RUN A BOTTLE OF SEA FOAM THOUGH IT BEFORE REPLACING PARTS. YOU CAN GET SEA FOAM AT ANY AUTO PARTS STORE FOR ABOUT $9.00 A CAN.
Dec 14, 2008 | 2006 Chevrolet Cobalt
Headlights don't work on 2006 Chevy Cobalt
there is a problem with the fuses getting wet under the hood, it has been causing alot of problems with headlights you may want to check there for anything
Sep 20, 2008 | 2005 Chevrolet Cobalt
Air Conditioning and Heat for Mazda Tribute Logo
110 people viewed this question
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
David Burbee
David Burbee
JOHN LAPIER
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
