Question about HP PSC 2110 Color Printer
I am not sure I have the correct cable to connect the HP 2110 to my pc. Where do I plug the cord in?
  • calla307 Jun 23, 2009
    That is what I have. The USB is plugged into the back of the computer and the other end to the back of the printer. The printer works when you make a copy, it just does not work when you scan or print. I have downloaded printer drive again and I don't have a clue as to what to do next.
  • 2,229 Answers
Do you have a USB cable?
The flat end plugs into a USB port on your computer.
The squarish end plugs into the printer. In the back, If I remember correctly, near where the power plugs in.
Hope this helps.
Posted on Jun 23, 2009
  • Art Ellison
    Art Ellison Jun 23, 2009
    That's not the question you asked. You wanted to know where to plug it in!
    Do you have the correct driver for your version of Windows?
    Is the printer set as the default printer?
    Did you load the software BEFORE you plugged in your printer?
How do i connect to a printer
Hi Jenelle
I think we will need more information to be sure to fix this problem, like the model of the printer and are you trying to connect to it with USB cable or through network (with LAN or with wifi).
in most cases anyway make sure the wires are connected correctly (USB) and download the below link to identify and install your printer if it's not installed correctly.
press the identify now button after connecting it with USB.
HP Support Software Drivers
May 23, 2016 | IBM ThinkPad Computers & Internet
Check line cord phone mean
The cord or cable connecting the phone to your pstn line is called line cord. check the connection at the back of phone and the wall jack. if it is ok change the cord and check.
Jul 20, 2013 | British Telecom Synergy 2110 Cordless...
Have many bran new hp La1905wg compac monitors with computers. Have powered up and get no signal then monitor says going to sleep. All do the same regardless of what monitor cable is used. What is...
Hello there,
Step 1:
Check all connections make sure everything is connected correctly .
The monitor should have two cords one for power and one VGA to the PC make sure both are connected correctly.
Step 2:
check the input on the Monitor make sure you are on the correct input for the type of Cord you are using.
Step 3:
If you are still not able to get a Picture try using the Monitor on a different PC it may be a bad Monitor, if you move the monitor to a different PC and it works then its the Graphics Card in that PC that is not working .
if you move the monitor to a different PC and it doesn't work then its the Monitor.
Thank you don't forget to Rate
Jan 25, 2011 | Computers & Internet
After a power cut my HP 2110 will not power up....but everything else connected to that plug PC/Router/Monitors do, any advice?
have you tried it with some other power plug?
If yes then i think your printers power supply has burnt
Jul 10, 2009 | HP PSC 2110 All-In-One InkJet Printer
Connection between computer and monitor!!!
The cable for the monitor has to plug into the desktop. So it's a VGA cord or DV Cord depending on the type of video card you have on your desktop. Some have a built in VGA port. Make sure you connect this to your desktop.
12_17_2011_8_16_49_pm.jpg12_17_2011_9_02_50_pm.jpgThis is the cable
Jan 09, 2009 | HP Pavilion M9040N Elite Desktop PC
Psc 2110 carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Nov 02, 2008 | HP PSC 2110 Color Printer
I need a replacement usb cord from my HP psc 2110 printer connection it to my pc.
You can try to any nearby stores like Office Max, Best Buy or any computer shops and ask for a standard USB printer cable. You can even check on www.compassmicro.com or www.nationalpartsdepot.com.
Oct 11, 2008 | Office Equipment & Supplies
Hp 2110 printer
You can get this cable at any computer shop. Just go with your damaged cable and show them.
Apr 23, 2008 | HP PSC 2110 Color Printer
HP psc 2110 all-in-one wont print from internet
I'm assuming you went to the HP site and downloaded the Vista drivers??? Other than that try this:
  1. From Control Panel > printers... uninstall all printers.
  2. Unplug USB cable to printer and re-boot.
  3. Install Software.
  4. Plug USB cable back in.
Hope that fixes Ya...
Geno
Mar 26, 2008 | HP PSC 2110 Color Printer
Hp psc 2110 incorrect ink cartridge message.
when ever i get that message it's when i use a "Non-HP" replacement cartridge...try using a HP catridge, or most likely, the printer has reached the end of it's usefull life!
you can try a "full reset" of the printer by..
-unplug it and let sit for a little while,
-BEFORE plugging it back in, press and hold both the enter and cancel buttons,
-plug the power cord in, and wait to release the buttons until the display on the printer tells you to,
-in many cases, this corrects some problems (especially that awfull grinding/ratcheting noise).
after many years of faithful service, i think mine is officially dead though...even the full resxet doesnt help.
Oct 26, 2006 | HP PSC 2110 Color Printer
HP PSC 2110 Color Printer Logo
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
