Question about Chamberlain Liftmaster Professional Remote Light 395lm
The door goes partially down then back up. The lights flash. What can I do to fix this?
It will go all the way down if I hold the button for the duration.
    Problem Solver:
  • 19 Answers
Check your safety photo eyes are lined up. you will have one on each side of the door on the bottom by the guide tracks. you should be able to see an LED "light" solid is good flashing is bad.
a solid light means the the photo beam is good from one side to the other and you should be able to block the beam with your foot and see the led go from solid to flashing.
Posted on Sep 01, 2014
My garage door starts down then goes back and the motor light flashes 10 times. The owner's manual only refers up to 6 flashes.
Richard, what is the make of your GD Opener unit? However, make sure the antena wire on the unit is turned up. 2. sometimes direct sun on the sensors prevent operation from the remote. 3.adjust sensors on both sides making sure the green or red lights are on.4. check the remote battery ensuring red light works when you press the remote button. 5. finally, has on vacation switch on the unit has not been switched on. GL
Dec 01, 2014 | Building Materials
I changed the cartridges in my 1315. Won't print or scan and reads door open
The below steps is not confirmed that it a fix, but you can try the below step. This is called as a printer partial reset. Uses fixes most of the general issues. Clears the memory in the printer (speed dial etc..)
  1. Disconnect the power cord from the back of the product.
  2. Wait 60 seconds.
  3. Reconnect the power cord to the back of the product.
  4. When the lights on the product control panel begin to flash, press and hold the On/Resume button (c01590957.gif ) and the Size button. Illustration: Press and hold On/Resume and Paper Size buttons c01581916.jpg
  5. When only the On/Resume button (c01590957.gif ) is flashing, release both buttons. The reset is complete when the button light stops flashing.
  6. Try printing again.
Aug 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Jun 19, 2009 | liftmaster Chamberlain Garage Door Opener...
I have a sears craftmen garage door and the control switch on the wall light keeps flashing and I need to know how to get it toa solid light and when I press the button to close the door it goes few...
When the door reverses to the open position and the main light flashes 10 times it is a door sensor problem. Usually the sensors get bumped and need to be tweaked so that they are once again pointed at one another. Each sensor has a small light that must be on for them to work. The light on one sensor stays lit all the time and the other sensor light is only on when they are pointed at one another.
The flashing light in your wall control is a separate problem. One of the buttons on the wall control has an icon of a lock. Press and hold it for 3 seconds and release. It should stop flashing.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote does not open or close garage door; inside button flashes
What has happened is that you electric eyes are blocked or have gone out. The eyes are at the garage door about a foot of the ground on both sides. There should be a red or green light on one of them. If not some thing is blocking the beam that goes across the door. It is a safety beam so kids can nt get hurt when the door is coming down. If the beam is broke the door will go back up.
Jan 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Door does not open
Try: Hold down "end of cycle" till the door light goes off.
or Hold down "start" & "pause" button together till light goes off. Caution, after light goes off, wait for 2 or 3 minutes before trying the door, do not force door.
Pl post back result..........
Jun 10, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Door ups and downs
Holding the button down just bypasses the sensors.
Your sensors are not adjusting correctly, or there is a short in the wires.
The back of the machine has a little yellow light, count the flashes and corelate it to the troubleshooting portion of the manual to confirm.
The orange light is a constant, the green sensor needs to be adjusted until you get a solid green light.
Apr 30, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Oven door will not close because the door lock is on and flashing, also the oven light won't go off. how do I fix the door lock flashing so I can close the oven door completly?
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 03, 2008 | Ovens
Chamberlain Liftmaster Professional Remote Light 395lm Logo
67 people viewed this question
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
