Question about Refrigerators
Evakool fridge error codes
Our fridge keeps displaying E1 when we plug in. What does this error code mean? It is not listed in the manual.
  • Julie Capes
    Julie Capes May 11, 2014
    The fridge is an EvaKool 55L, sorry, forgot to specify!
dididsaythat
  • 291 Answers
SOURCE: Error Code E1
got a model #
Posted on Sep 02, 2007
SOURCE: Beko AP930 with Error code
Error codes are printed on underside of plastic cover on top of fridge. Warning electrical components inside! Error code E0 is the FREEZER door not being recognised as closed, switches are normally ok may be problem with printed circuit board. Freezer will work as normal but engineer should be called.
Posted on Aug 29, 2008
SOURCE: LG refrigerator error code
Had the same problem + a weird noise, which turned out to be ice build up on the blower fan. Unplugged overnight and then opened the lower back panel. There is a small fan that blows over some small coils at the bottom of the box. There is also a drip pan that should be "full" of water. I sponged out the drip pan, put the panel back on and then plugged back in. Works great.
Posted on Nov 04, 2008
SOURCE: Error code F32 for fisher
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Posted on Nov 09, 2008
SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Posted on Nov 17, 2008
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
    highly annoying issue error code E1. After hours
    of fan operation, the error code E1 will appear on the seven segment
    LED temperature display. This error code is intended as a reminder for
    the user to clean the air filter. However, because the procedure
    outlined in the user manual does not clear this error code as
    indicated, and the appliance has a nonvolatile memory that cannot be
    reset by simply unplugging it, the user of the appliance will become
    mightily frustrated, standing in potentially sweltering heat watching
    the appliance repeatedly shut down in the midst of operation with the
    "E1" display flashing.
    Believe it or not, that is what it does: if you unplug it to remove the
    "E1" code from the display, and plug it back in and re-start it, it
    will simply run for anywhere from a few minutes to a few hours, and
    then merrily shut down again with the same flashing "E1" code.
    So you will come home to a hot bedroom, living room, etc. unexpectedly,
    and you will NOT be amused, as I was not.
    Many people at this point, having put the manual under the canary or
    some such, will simply return the unit and never buy another Sharp air
    conditioner. But for the tech-savvy and search-adept, I offer the
    following procedure to clear the nefarious E1 indication, and obtain
    1. Power down the air conditioner using the "power" button on the front
    panel.
    2. Unplug the air conditioner from the wall socket.
    3. Hold the front panel "power" button down and plug the air
    conditioner in. Continue to hold the power button down as the machine
    goes through a brief test sequence (fan & compressor each come on
    briefly, etc). There is a "beep" sound at the end of the test sequence,
    and the machine will be off. At this point, you can release the power
    button.
    4. Unplug the air conditioner.
    5. Plug the air conditioner back in.
    6. Congratulations! You should now be able to operate the air
    conditioner normally for another 720 hours, but only if you followed
    the instructions above EXACTLY.
    _____________________________________________________
    Was this solution helpful? Show your Appreciation by rating it.
    Thanks for using fixya support..You have a wonderful day
    Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
    In the window then note comes up E1 ERROR . What is this. It does not sew.
    Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
    Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
    Frequently Asked Questions
    Why is my Kenmore sewing machine locked up with an E1 error code displayed...
    Simple Fix for Janome E1 Error
    Feb 14, 2016 | Sewing Machines
    What does E1 error mean
    Sorry but with no make how can we check .
    Dec 15, 2015 | Sewing Machines
    Error code E1 and E4
    PDF]SERVICE Manual - Quietside
    https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
    When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
    Midea air conditioner error codes
    airmaster.net/midea-air-conditioner-error-codes/
    Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
    [PDF]Download the Fault Error Code Booklet - Samsung
    Dec 05, 2015 | Heating & Cooling
    Haier washing machine keeps stopping and displaying error code E1
    As said in the question you are haier washing machine keeps stopping and displaying error code E1 this is due to the Error signal due to Pr. Sensor.This problem can be solved by only service Engineer.Thanks for your question.
    Jun 20, 2011 | Washing Machines
    My unit shut off now displays E1.
    Sharp updated the procedure for resetting the E1 code.
    1. unplug unit
    2. hold the Power button while plugging the unit back in
    3. keep holding the Power button until the unit beeps
    4. unplug unit again
    5. plug it back in and it should be good
    Here is the updated user manual
    http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
    Jun 05, 2010 | Sharp AF-S120FX Air Conditioner
    Error Code
    open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
    Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
    HOBART AM15 DISH WASHER ERROR(E1)
    After checking the service manual, I find no code for E1. There is a P1, or other E codes. Please list ML number.
    Jun 14, 2009 | Hobart 29 in. AM15-1 Free-Standing...
    Error code
    Do you still the warranty for this unit? maybe you should contact the company which you bought the unit.
    May 31, 2008 | Haier hwr10xc6 Air Conditioner
    Refrigerators Logo
    165 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
