Question about Traxxas 1/10 4WD Rally Racer Brushless RTR w/TQi 2.4GHz Radio
I have a two week old traxxas rally (1/10). It was working like dream one day, the the next time I used it (running both types of batteries LiPo's and standard), it was sounding like it was struggling, it was sluggish, at full speed no where near usual top speeds. I stopped the car checked it and noticed smoke coming out the back. I took of the top gear box cover to have a look. I should smell something burning but no visual signs in any of gearing. It all looked fine. Can anyone suggest what might be the issue.
    New Friend:
Try tightening your slipper clutch. tighten nut all the way, then back it off aproxamently 1/3 turn. also check all electrical connections. a loose wire, especially your ground wire, can cause excessive heat and smoke
Posted on May 19, 2014
I have traxxas bradit xl5 and the hi low votl detector stop working how can i fix the problem
If you use Lipo :
Buy a Lipo buzzer/low voltage alarm and use that instead, that vist only a few $. Attach it on tha balance plug on the battery. When it start making noise/buzz stop driving.
Using NiMH:
When the rc gets really slow - stop driving :-)
May 12, 2017 | Traxxas Toys
Using lipo s it goes to low voltage shut off
the packs may need to be balanced..most good chargers have an option to balance your packs out..one cell may be stronger so it is running off that cell then acting dead
Apr 08, 2013 | Traxxas Toys
Traxxas bandit vxl doesn't work i left my traxxas bandit vxl for 1 day and came back and drove and when i got outside and drove pass my sidewalk to go on the road the esc started flashing red slow
Are you running a lipo or nmhi? You could have the lipo cut off turned on and the battery is too low. Or it could have a bad motor. Try hooking up another motor an see what happens. Or try to turn off lipo mode.
Mar 13, 2012 | Traxxas Bandit Vxl Brushless Buggy
Problem with my traxxas stampede xl5 just stopped working.
It sounds like the battery is defective, that causes it to lose it charge very quickly.
Jan 26, 2012 | Traxxas Stampede Monster Truck Rtrw/Xl 5
The light, on the XL5 turns red when you turn it on.
thats probably because you are using a nimh battery and lipo low voltage detection is off
Sep 23, 2011 | Traxxas Stampede Monster Truck Rtrw/Xl 5
I just got a traxxas stampede in dec. i have used it about ten times and now i am having issues when i go to turn it on the green light on the esc comes on and then goes to red and then the light goes off...
make sure ur batteries are fully charged and ur using the right ones for ur model reset ur transmitter to factory default, it sounds like the esc is detecting something wrong when u go to use it bad battery if its a lipo may have ran it to long which can mess them up, I would clean the button on the esc really good, if the truck is making that noise the esc will try to shut down the system if all else fails send in ur esc to traxxas and they will send u a new one for like $50 buck let me know if u get it going
Aug 22, 2017 | Electric Traxxas Stampede Xl-5 Rtr ...
The LED on the XL-5 is solid red after programming. The model operates normally, but the light is supposed to be green. What is wrong?
Press the ez-set button on the esc (the one with the heatsink) for ten seconds until it changes color and gives a beeptone,green is low voltage detection on for use with lipo batteries,if they are fully discharged they are dead,the detection system cuts power beyond 3v per cell so that the lipo isnt dameged
Dec 25, 2010 | Traxxas Rustler Vxl Rtr
Vxl-3s velineon problem with speed control
This problem is very common with the traxxas vxl 3-s speed control. If you were previously running it in 70 degrees or above without a cooling fan, hobbytown is correct. If you have a fan, or it is cool outside, try your best to return the speed control for a new one.
Jun 21, 2010 | Traxxas Toys
Traxxas stampede eletric r/c
The first thing to check is whether or not your speed controller is in Lipo mode or NiMH. If you are using NiMH, and the ESC is set for Lipo, it will not work properly. If the ESC is in NiMH mode, then try reprogramming the speed controller, as this has been my problem a couple of times. Good luck, and have fun. Hope this helps.
May 05, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Traxxas 1/10 4WD Rally Racer Brushless RTR w/TQi 2.4GHz Radio Logo
99 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
