How do I fix error 99 on St. Louis turntable, cd, cassette player model 541.809?
When I put a cd into this player, it appears to be trying to read the cd but then the number 99 comes on the screen and then it says error. The cd never plays. Anyone have any suggestions?
  • Audio Player... Master
  • 5,487 Answers
Most of these reading errors are caused by dirt on the lazer lens. You can buy a cleaning disc that should solve the problem. If it doesn't then it might be more serious such as damage to the lens itself, or an electronic fault.
Posted on May 24, 2014
  • 104 Answers
SOURCE: Streched CD drive belt
turntableneedles.com has about 450 belt sizes in stock. your unit is too new to have this listing yet as the belt should not have failed already so when you call be ready with the length of the old belt. Don't worry that it is stretched, a new size will be calculated that is about 3-5% shorter.
Posted on Feb 11, 2009
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
Grubhead
  • 5487 Answers
SOURCE: ION turntable volume is low when plugged into a receiver.
Either the cartridge has failed, or an internal amp in the record deck has, or despite what you say the receiver has. I will clarify this for you. Magnetic cartridges need a pre-amp before it gets amplified by the pre-amp and power amp of your reciever. If that pre-amp fails you will still hear the low sound from the deck, but all others cd/tape would be normal as they don't go into the deck pre-amp.
All you need to is trace the circuit. Find the magnetic cartridge pre-amp and find where it joins with the pre-amp of the amp! If you stick a screwdriver at that point, you will get a buzz at normal volume on each channel. The cartridge pre-amp has gone if you do get a buzz!
You probably find it's a single IC that's gone, some are prone to static problems.
Posted on Jan 05, 2010
SOURCE: My Crosley combination turntable/CD/cassette/AM &
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
Posted on Dec 10, 2010
  • 3 Answers
SOURCE: Thomas Pacconi Model TPC-MSE-800 turntable
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Posted on Jan 21, 2011
My Spirit of St Louis CD, Radio and cassette player is great. However the CD player won't open anymore. How can this be fixed?
Are you opening by pressing manual control or by using remote control? Quite often there is a small ' pinhole aperture next to the DVD drawer - if so , use a straightend paperclip to push into the hole in order to release the drawer.
Oct 21, 2016 | Miscellaneous
How do I turn my turn table on. POWER button is on. What other button do I push. I have phono, mono/st, cd, tape, tuner??
Phono button is turntable selector. May be the turntable switches on when you move the arm to the edge of the record.
Dec 17, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Is there any universal remotes that will work with a spirit of st louis radio, cd player, and phonograph? son broke the remote.
There are, but it's..... hit and miss.
The remotes don't cover all remote devices.
You will need the serial # and the brand B-4 you shop for a remote.
Not available from the manufacturer?
Nov 12, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Need a needle for a spirit of st louis turntable cd cassette player. do not know what kinnd or model to buy
Do you have the old needle?
If so, you can match them up to charts provided by dealers.
If not, try to find out the make / model of the turntable chassis.
Providing some close up photos that would be a big help.
Mar 05, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
I have a Spirit of St. Louis turntable that won't turn.
This model of turntable automatically stops when the needle reaches the center(the end) of the record. The motor should turn back on if you move the arm to the far right of the player, past its resting spot.
May 02, 2013 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Record player does not move
more info needed - could be that the 'belt' driving the turntable has slipped or broke - what type of player is this?
Jul 18, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Turntable won't turn
There is usually a cotter pin at the center of the platter around the spindle base. This can be removed with a screw driver using a twisting motion. There is a blades worth of space between the clip and the spindle base. Screw driver should be in vertical position. Sometimes the vinyl slip mat must be removed first. Watch that clip, cause it can go flyin. Once the clip is removed, the turntable should let go easily.
May 03, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
78 people viewed this question
 Grubhead
Grubhead
