Question about Samsung BD-D7500 Player
Region change from 1 to 4 - Samsung BD-D7500 Player
How do I change region code on Pyle pd1000a? Need region 1 and all I get is not formatted to play in this region error message. Don't know what region this thing is programmed to but need to change. Pyle...
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player.
Region 1: U.S. and U.S. Territories, Canada
Region 2: Japan, Western Europe, Middle East, South Africa
Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/
South America
Region 5: Russia and the former Soviet Union, Africa, Indian
subcontinent, North Korea Region 6: China
The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is legal in all countries.
Google for the programs.
A DVD player sometimes allows you to change the region code once. But it not even would allow you to switch back after you changed it once.
Jul 23, 2014 | Pyle Audio Players & Recorders
Laptop dvd player stuck on region 1 need 4 for
Try changing the region by right clicking your DVD drive in explorer and select properties, go to hardware tab, select your DVD brand and type, click properties, go to DVD region, and change the region.. Just remember, any DVD only allowed to change the region for about 4 times, after that, you can't change the region anymore..
Dec 23, 2009 | Toshiba Satellite A135-S2276 Notebook
PHILIPS DVD player 616K, how to change region or get into right region. my player was working OK. Suddenly it stopped functioning and showed/diplayed '' wrong region'' on the TV screen.
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', '0' in that order
if that dont work go 1, 1 1, 1 in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
note: you want to chose region 0 so u can use all regions
Nov 15, 2009 | Computers & Internet
Change DVD Region Code
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__okj4
Oct 15, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
DVD drive ''Free'' Region code does not play Region 1 DVD
You cannot see region 1 movies unless you change the region code, its designed this way as an anti piracy measure.
Oct 03, 2009 | Computers & Internet
How i change the region
You cannot change the region code. The USA only works in Zone 1 and all your discs should display this image: 905cf1d.jpgmoz-screenshot-1.jpgmoz-screenshot.jpg
Jul 08, 2009 | Bose (321GS) System
Samsung DVD-VR375 - can't chage from region 1 to region free
I used this and it worked for me!:
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jun 20, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Region changing
Make your dvd player region free like this:
It works for NS50P, NS575 and the most models of the families NS50 e
NS500.
With the DVD player turned off(stand by), press:
TOP MENU
CLEAR
POWER
Choose option 2 and after option 4. Type:
12450 [press enter]
00000 - Then press enter and power off.
DVD will now be region Free.
Feb 22, 2009 | Sony DVP-NS50P DVD Player
Getting Region 1
All the recent DVD drives have the region set in the hardware. This can be changed, however it can only be changed a small number of times, ( usually 5 ), after which it locks.
Because you do not live in region 1, I recommend that you get a second drive and set it to region 1. When you buy a DVD drive the default region code is the same as the region in which the store is..
Not sure on the details, but I think the software that came with the drive can change the region. Read help.
Region codes are a curse and one of several reasons why people illegally copy movies.
Feb 16, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Samsung BD-D7500 Player Logo
55 people viewed this question
Henry  Thomas
Henry Thomas
