Question about Panasonic Lumix DMC-FZ8 Digital Camera
Is rechargeable Li-ion battery available for Lumix DMC FZ8 in service center and how much?
I bought a Panasinic Lumix DMC FZ8 Digital camera in a garage sale but no battery where can I buy the rechargeable Li-ion Baterry?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,554 Answers
  • 74 Answers
SOURCE: installation for LUMIX DMC-LS2
The Arcsoft software that comes with most, if not all, Panasonic cameras is available as a trial download on the internet. The free version is only available on the disk that came with the camera. However, if you are using Windows XP (or maybe even Vista) you can use a free photo edit/organizer program such as Google's Picasa. As long as your computer recognizes the camera when connected, you can use most any software. If this doesn't work, you can try using a usb card reader and removing the card from your camera and accessing your images that way.
Picasa
Hope this helps.
Posted on Oct 18, 2008
welcomejee
  • 10594 Answers
SOURCE: Need replacement instructions for my DMC-FZ30 digital camera
You can download required user manual from HERE or click Panasonic Support and type model number in box to get manual.
Posted on Jan 13, 2009
SOURCE: Inoperative Panasonic Lumix DMC-FZ8
I had this issue and found a small grain of sand around the lens. On removing it the camera worked fine again.
Posted on Jul 13, 2009
  • 83 Answers
SOURCE: Use of digital camera Lumix DMC-LS70 as a web cam.
It will not work through USB like a standard webcam. Ls-70 only lets you access camera memory card/onboard memory when connected via USB.
However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
There are also various software solutions which can fool your webchat client into thinking that video capture stream is actually an output of a usb webcam. (Try google for "video capture into skype".
At the moment this seems to be the only easy way to use LS-70 as webcam.
Good luck,
Raf
Posted on Nov 05, 2009
  • 11967 Answers
SOURCE: Replacement cable for Panasonic Lumix DMC-FZ5
Forget the cable. Do what the pros do...use a card reader.
Posted on Jan 23, 2010
Service center philippines
Hello Susana, we recommend you contact our Asian counterparts available at the below link so they may properly assist you.
https://www.facebook.com/panasonicasia
May 10, 2014 | Panasonic Cameras
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
Dropped my Panasonic Lumix DMC-FZ8 in a stream - its dried out & works fine except there's a stain on the inside of the lens. How is this best cleaned? tHX
You cannot clean the inside of the lens. If it must be cleaned, it needs to be disassembled by a Panasonic service center, cleaned, reassembled and re-calibrated, and then returned to you at an enormous cost. You need to determine if it's worth it.
Jan 03, 2011 | Panasonic Lumix DMC-FZ8 Digital Camera
Using instructions required
You can download the Panasonic Lumix DMC-FZ8 Manual ( Operating Instructions) here:
Panasonic Lumix DMC-FZ8 digital camera Operating Instrutions (10.7MB)
Have fun :)
Apr 18, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
May lumix dmc fz8 dropped into salt water and won't turn on?
Do not insert cell or battery in your camera & do not try to switch ON the camera. otherwise it will harm your device.Send your device for repair, there is no other way to fix the problem.
Good Luck..
Feb 28, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
How to charge Panasonic lumix DMC-FS4
hello there use your USB cable for charging your camera battery. No need to take out the battery from camera. Some Tips.
  • You may choose our Smart Charger (0.5A,UL listed) for 3.7 V Li-Ion battery Pack to recharge this battery pack. Must charge the battery pack with correct polarity. The estimated charging time is 2.76 hours .
  • You may connect two 3.6v 920 mah pack in either series or parallel connection for making a higher voltage and higher capacity pack.
  • Hope you have those staff with your camera. use that for charging. Follow the link.
    http://www.batteryspace.com/smartcharger05afor37vli-ionpolymerrechargeablebatterypack--ceullisted.aspx
    Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
    Jan 31, 2010 | Panasonic Lumix DMC-FS4 Digital Camera
    Panasonic lumix dmc-fz8 shutter button cracked
    Hi dear, you can try to order the parts from Panasonic and do it yourself.
    I strongly recommend you bring your camera to an authorized repair center to get it fix by them.Because it looks simple to open the camera but it's not.
    Jan 17, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
    I've lost download software for my DMC-FZ8 vanishnow@gmail.com
    You should be able to download your pictures with almost any graphics program. You can also use the program that came on lab lade disks a few years ago. You can try the manufacturer for a program, if you registered when you bought it.
    Jan 08, 2009 | Panasonic Lumix DMC-FZ8 Digital Camera
    Panasonic Lumix DMC-FZ8 Digital Camera Logo
    127 people viewed this question
    Top Panasonic Cameras Experts
    Are you a Panasonic Camera Expert? Answer questions, earn points and help others
