Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Can i put a peerless in place of a dana4361-140?
Dana trans axel craped out cant get parts. can I put a peerless in its place
    New Friend:
  • 83 Answers
I do not know the answer but go to this url and call them. They should be able to help you.
https://riversidemowerinc.stihldealer.net/
Posted on May 11, 2014
2 Suggested Answers
bahama_mama0
  • 7 Answers
SOURCE: Blown Tranaxle.
if it is still under warranty and it was from normal wear they will replace it but if not under warranty you'll have to buy a new one,and they can be costly.
Posted on Oct 06, 2012
How do I get parts for hydro-trans for rtz-50 Troy Bult lawn mower
It could be a peerless hydro ,there is a tag on the trans with a model # on it google peerless on the web for parts.
Oct 01, 2014 | Garden
How to fix brakes on a John Deere S92 tractor ?
aaa hhh an oldie but a goodie i used one of these to cut around the pen posts and other tight spots around the place 4 years, anyways if this is got the 5 speed peerless trans on the right hand side (facing forward) of trans there is little metal wheel with a small shoe on it there is a slip bolt that runs thru top of that there should be a nut on the end of it give this a turn or two when nut bottoms out on shaft its time to replace the shoe (sorry but they finnaly took down the youtube video i had of peerless trans rebuild ) anyways a nice one to own turns on a dime
May 06, 2014 | John Deere Garden
Blown Tranaxle.
Sep 25, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 2003 toyota highlander with a failed cv joint. I want to change the whole axle, but i cannot get the axle out of the transaxle.
Okay after you get the outter part of axel free with rotor off and everything ,,,you have to get a small pry bar or flat screw driver what ever works and pry the small hub right after the boot there should be a small space where you can fit the pry bar between the hub on axel and trans houseing and pry it out Im doing a hyundai right now and looking for that just right space to do the same thing,,also when inserting the new axel it will push right in and you will hear the click when in all the way, if you cant get it send me a pic of the axel inserted into trans,,,,,,,,thunderz@live.com Ill help you get it out.
Feb 22, 2011 | 2003 Toyota Highlander
I need to remove the driver side axle and i cant get it out of tranny
There is a "C" clip that holds it in there. Put your pry bar on the fat part of the halfshaft (axle) and give it a few smacks with a hammer. These jolts should knock it loose to be able to remove it. If you cant get room to hit it with a hammer you will have to use a pry bar and just keep working at it on both sides.
Jan 15, 2011 | 1996 Dodge Neon
How to replace 1996 dodge neon cv joints
Remove the wheel and the lower ball joint from the spindle. It will also make it easier if you remove the tie rod end. There is a large hut at the tire end of the axel. Remove that nut and washer. Take a rubber or brass Hammer and hit the end of the axel to push it through the bearing assembly. If it is really stuck, put the nut back on so that the nut is even with the end of the axel and uses a heavier hamer to break it loose. Once you break it loose, pull back on the rotor while pushing the axel to remove it from the hole it passes through. (Becarefull with the brake hose. If it is pulling too tight it might be best to remove the caliper and use a hanger to suspend it until you are done.) You will need a really BIG screw driver or a pry bar. Put the pry bar between the case and the hub of the axel and push in quickly and firmly to pop it out of the trans axel. It might take a few tries. If it resists look for a ridge and put a big screw drive on the ridge and use a hammer to pop it out.
Once it is out, reverse directions. Do not use the hammer on the new axel any where.put the end into the trans axel as far as it will go and then put the other end through the wheel bearing. Use the leverage you have with the rotor and bearing side to push the axel into the trans. You should hear it snap into place. Before you put the ball joint back on go to the trans axel side and use that pry bar and gently try to remove. if it resists it is seated, if it slides out, you need to seat it again. ONce you are sure it is firmly seated back into the trans, you can bump the ball joint and tie rod back together.
Good luck and be careful
Rich
Aug 18, 2009 | 1996 Dodge Neon
Hi, Ineed 5 speed Peerless transmisson for a troy
if you are handy you can take it a part and replace the parts inside. or drive around the country and find a mower with no engine for cheap. go to the Tecumseh web site to see witch trans are the same most bolt up
Jul 21, 2009 | Garden
I just bought a house and the garbage disposal is a peerless, it hums but doesn't run. I hit the reset button but nothing changed. I bought a wrench they said to insert in the middle and turn the opposite...
Home Depot sells a disposal wrench that you use from the top side. When it's held, it looks kind of like a T but the top part will pivot so it will go into the opening. You can use it to try and turn if from the top. If this doesn't work, then replace it.
Apr 08, 2009 | Peerless Industries Peerless Wall Mount...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
69 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
