Question about Kenwood Audio-video Stereo Receiver Kr V106r
How can i repair amp
When power is turned on makes a loud pop, and spikes volume
  • Kenwood Master
  • 9,633 Answers
Check to see if your amp has relays in the output lines. If so, they are designed to prevent you hearing the pop at power up which can damage your speakers. Relay contacts wear and the control circuit that operates the relays may have a problem.
Posted on Feb 21, 2016
    New Friend:
  • 21 Answers
Looks like the amplifier output transistors have blown (hence the pop). Quite expensive too repair - I would have a look on eBay for a cheap used but working Kenwood receiver, it would probably work out cheaper.
Posted on May 15, 2014
NHT SubOne makes hum when the standby mode is activating and when playing music there are pops when the volume gets loud.
Hums are generally caused by electrolytic capacitors that have gone. You should replace any large ones in the power supply section of the unit.
May 28, 2017 | The Audio Players & Recorders
When I turn my receiver on it makes loud popping noises from speakers. I repeat turning it off and on until it doesn't have the popping noises and then everything runs normal.
Its likely a dirty contact on safety relays or volume track.
Remove power and rotate volume min to max 5or 6 times.
Or it needs safety relay contacts cleaning/repairing or ensure the volume is turned to bottom before you end up popping a cone on your speakers.
Nov 18, 2014 | Audio Players & Recorders
How do I replace a subwoofer potentiometer ?
If the 10k resistor is the variable volume one then change it.Some sub amp plates have epoxy all over the pcboard.Hard to remove type.I think yours is soldered to a sub pcb and need soldering experience to remove.
Sep 14, 2014 | Polk Audio PSW111 Speaker
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
Their was a blackout in my neighborhood. The next day in the morning i tried to turn on my 50inch HP Plasma and it made a loud popping sound. The volume on the tv still works.
Hello.
You probably did not have that tv plugged into a surge protector. When the power was restored, a surge came through the line. A power surge is a spike in voltage above the maximum a tv, appliance etc. can handle of 169 volts. They are very brief, usually lasting millinths of a second. Power surges can vary in duration and magnitude, varying from a few hundred volts to several thousand volts.
That said, now what do you do. If the tv is under 3 years old I recommend that you take it into a local TV repair shop for a free estimate of repair. If it is older than that, I would not repair, just replace. J.
Sep 12, 2010 | HP Televison & Video
Pop and Hissing after turning on Tannoy 6D
It happens, don't be upset. Call Tannoy and get an RMA # . They will repair under warranty. When you get it back it will be as good as new. Rob
Feb 27, 2009 | Tannoy Reveal 6D Speaker
When i turn on my amp it makes a loud beeeeeeeeeeeeeeeep.
Turn the volume down.
Check your gain.
That should solve it.
Feb 05, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Power indicator is flashing after volume spiked and unit shut off
You can try a hard reset: Unplug unit from AC mains and remove all cables from unit . Wait about 3 hrs and replug to AC power and redo the cabling. Switch on the unit and see if it works..
Sep 26, 2008 | Denon AVR-1082 Receiver
Loud Pop,Crackling, Dead Unit
What it might (definitely) be is a big repair bill. Alot of mfg's don't put fuses on the amp sections. They use relays.
It's probably a transistor or power amp module that fried.
What initially may have happened is that: You got a power spike and it weakened the internals. Happens to PC power supplies quite a bit.
Jul 07, 2008 | Samsung HT-Q70T System
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Kenwood Audio-video Stereo Receiver Kr V106r Logo
98 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
