Question about Cub Cadet Garden
Where is the drive belt located on cub cadet lt 1045
I was mowing with my Cub Cadet LT 1045 when it suddenly stopped moving. Starts and runs great but will not move forward or backward. I was thinking that it may be the drive belt but I don't know where it is located and how to get to it. Can anyone help me with that?
5 Suggested Answers
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 176 Answers
SOURCE: looking for a diagram for
TRY CONTACTING CUB CADET MANUFACTURER
Posted on Aug 29, 2011
BAMOUT
  • 2478 Answers
SOURCE: need wiring diagram for cub cadet lawn mower lt1045
Posted on Mar 15, 2012
  • 6468 Answers
SOURCE: 2010 Cub Cadet LT1050 suddenly dies when blades engaged
check the safety switch on the seat
Posted on Sep 03, 2012
I have a 2006 Cub cadet LT 1045. My model only has one idle pulley. I am having a hard time keeping belts on. Does anyone know a fix for this
have you got the belt on the right side of the idler pulley
the back of the belt should be running on the pulley
Sep 25, 2015 | Cub Cadet Garden
Why would my belt on my cub cadet 1046 mower keep popping off?
Did you put all the belt keepers back on? I find a lot of DIYers usually leave one off thinking it is not important.
Jun 30, 2015 | Cub Cadet Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Motor will not turn over by the key switch on my cub cadet lt 1045 but it will if i run a jumper from the battery to the starter post
When you jump the starter, you are bypassing the safeties.
Check the neutral/brake safety and the blade disengagement safety.
Gary
Jul 18, 2011 | Cub Cadet Garden
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Engine will not start
you have atleast 2 safety switches on there. one under the seat and one one the brake. if either one would fail, the engine will not turn over! i had to replace mine last yr
Jun 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
