Question about Sony BRAVIA KDL-52XBR4 LCD TV
What screw are used to fix kdl52xbr4 to the base? We have the pedestal but lost the screws
    Top Expert:
  • Sony Master
  • 75,591 Answers
Contact the autorozed dealer for Sony. They can provide you details of the screw. Gopakumar Gopalan Google
Posted on May 11, 2014
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: We lost the screws in
You need 4 screws to fix base stand with tv, part number is as follows:
258060801... SCREW, +PSW M5X16
Available in PartStore.com for $5 each, click that link to view screw image and price info.
AC cord part number is as follows:
183514311... Cord AC
Available in PartStore.com for $13
Hope this will help you.
Thanks.
Posted on Nov 15, 2010
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia KDL-V40XBR1. Lost the main screw to
Required screws part number is as follows:
258064001.... SCREW +BVTP2 4X16
Hope these info will help you.
Thanks.
Posted on Nov 26, 2010
How i fix my wobbly high chair
If you know someone that has a welder they could weld it . Or if you don't .and can get the pedestal loose from the base you'll see where the break is .I would cut a piece of plywood drill a hole in plywood the size of pedestal push it in plywood stand stool up push down . Till pedestal touches floor take drill .get some 1" self drill/tapping screws commonly called : TEK-screws put 3 screws in the wood at an angle so screws go into the pedestal to hold it tight paint or stain the wood.your handy work.
May 15, 2014 | Furniture
I have a kitchenaid K5SS. The beater keeps hitting the bowl even after adjustment screws was adjusted. What else can I do to fix problem
Check the four large screws at the back of the motor housing. They screw up thru the pedestal into the gear/motor housing. If they are loose that can allow the motor to tilt forwards. Check also the ones under the pedestal base, I have never seen those ones loose though and they would not cause your problem.
Mar 24, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Remove pedistal base from 24h898 aoc envision tv
You need to remove the cover that hides the 4 screws that hold the stand to the monitor. There are 3 pieces to the pedestal base. The base plate, the pedestal, and the screw cover. To remove the screw cover, look on the back where the pedestal attaches to the monitor. There is a cover just above the pedestal. Pinch the top left and top right sides (about one inch from edge) to unclip the cover. Remove the 4 silver screws (2 on each tab) and put them in a ziploc bag to avoid losing them. Tape them to the pedestal/base and cover.
Jan 18, 2014 | AOC 24 Envision L24H898 1080p Widescreen...
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
3) Remove the five screws shown in the diagram below. This will
4) Once you have removed all five screws holding the pedestal
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 18, 2010 | Toshiba REGZA 47HL167 TV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
HOW DOES THE DRAWER TO MY PEDESTAL BASE MODEL SBSD137H5WW , SERIAL NO. HR124045G COME OUT SO I CAN SECURE THE SCREWS AT THE BACK INTO THE WASHER AT THE TIME OF INSTALLATION? MY WASHER IS A GE MODEL...
Went back to Lowes to talk to a sales personal. He informed me that there are two screws at the front of the drawer (one per side) After removing these screws (you will need to put them back after) the drawer will be removable from the pedestal base.
Nov 13, 2009 | GE WSXH208A Front Load Washer
Missing pedestal screws for 3000 series 42 inch LCD. model 42PFL3704D
I just received the same TV (Philips 42PFL3704D/F7) in a box...with no screws to mount the pedestal to the TV. What size screws do I need to buy??
Jul 07, 2009 | Philips 42PFL3704D LCD TV
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
Sony BRAVIA KDL-52XBR4 LCD TV Logo
135 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
