Question about Rug Doctor Mighty Pro X-3 Ready Pack Commercial Grade Deep Cleaner
Water is coming from bottom of my rug doctor when using the hose
My Rug Doctor Mighty Pro sprays water from bottom of machine when I am using the hose attachment.
2 Suggested Answers
fixitcr63
  • 210 Answers
SOURCE: I have a rug doctor blue machine. It will not
Only two things can be wrong here, either the solution hose is plugged, kinked or undone from it's source, or the pump motor is not working. I'd try the hose first, if you can, take it off at the pump and then turn the machine on. If you get solution pumping out of the unit, then it's not the little pump motor and your problem is in the hose.
Posted on Oct 22, 2013
The switch on my machin will not go on what do i do their or whats wrong with that what do i do to fix it?I plug in the rug doctor then i flip the switch but it wont go on.
bad switch or broken wire in the cord . use a continuity tester to check from the plug to the switch. if the cord is good check the switch itself good luck
Apr 27, 2015 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Rug doctor will not spray what should I do?
check your spray pump is working a little pump inside machine is operating .check switch is working as well
Sep 02, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
My rug doctor will not spray out water
check your spray jets are not blocked but also check your small pump is working & operating that spray the water out of the nozzles
Sep 01, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
Water pours out from underneath
Check your hoses inside the motor area. One may have come loose.
Jan 16, 2014 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Keep triping out when pressing spray switch
Any electrical device could trip out if in contact with water, potentially dangerous find the leak and you've solved your problem. PBK
Dec 01, 2013 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
I have a rug doctor blue machine. It will not spray anymore. Great suction. It is connected properly. Any suggestions?
Oct 22, 2013 | Rug Doctor Mighty Pro X-3 Ready Pack...
Rug doctor repair manual
<Consumer.Support@rugdoctor.com> said: "Thank you for your inquiry about a schematic for the Mighty Pro machine. The only place that can be acquired is through Rug Doctor's manufacturing facility. You can contact our manufacturing facility at 800-964-4362 and ask for Parts. They will be able to provide you with what you are requesting."
Rug Doctor Consumer Support
Rug Doctor, LLC ' 4701 Old Shepard Place ' Plano, TX 75093
http://www.rugdoctor.com
Sep 07, 2013 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Rug Doctor Mighty Pro X-3 Ready Pack Commercial Grade Deep Cleaner Logo
21 people viewed this question
Top Rug Doctor Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rug Doctor Vacuum Expert? Answer questions, earn points and help others
